Give feedback
AI-assisted
Close
How do I verify that Claude Code can reach the Arm Performix MCP server?
Ask Claude Code to list available Performix recipes and profiling runs. If it returns recipes or targets, you’ve confirmed the MCP connection even when the run list is empty. When runs are available, request their IDs, targets, workloads, and creation times to choose one.
Which MCP configuration method should I use?
Configure through the MCP interface of the extension, run claude mcp add, or edit ~/.claude.json. The extension and Claude CLI share the same MCP configuration, so you need only one method.
Where should I configure the Performix MCP server when using VS Code?
Configure the server on the host where Claude Code runs. For a local VS Code session, set it up on the same machine.
What should I prepare before creating a new Code Hotspots run?
Choose a representative workload, specify the executable with an absolute path, and build with debug symbols when possible. Aim for at least 20 seconds of representative execution to capture useful samples.
How do I open the profiled run in Arm Performix to validate the AI recommendation?
From a terminal where apx is on your PATH, run apx run info "<run-id>". Use the returned workload, recipe, target, and timestamps to locate and open the matching run in the GUI.
