Measure and compare performance per watt on an Arm Linux system
Prepare the Arm Linux system
Discover CPU frequency and power controls
Collect synchronized power and thermal telemetry
Establish an OpenSSL performance and power baseline
Compare Linux CPU frequency governors
Compare CPU maximum-frequency limits
Calculate performance and energy efficiency
Inspect CPUFreq policies
Linux represents each independently controlled CPU frequency domain as a policy directory. List the policies:
find /sys/devices/system/cpu/cpufreq \
-maxdepth 1 \
-type d \
-name 'policy*' \
-printf '%f\n' | sort -V
Compare the number of policies with the number of online CPUs:
printf 'CPUFreq policies: '
find /sys/devices/system/cpu/cpufreq -maxdepth 1 -type d -name 'policy*' | wc -l
printf 'Online CPUs: '
nproc
On the Thelio Astra used to test the Learning Path, each CPU has its own policy. Other Arm systems can group several CPUs into one frequency domain.
Display the controls for the first policy in your list:
for attribute in \
affected_cpus \
related_cpus \
scaling_driver \
scaling_available_governors \
scaling_governor \
scaling_min_freq \
scaling_max_freq \
cpuinfo_min_freq \
cpuinfo_max_freq \
cpuinfo_cur_freq \
scaling_cur_freq \
boost; do
printf '%-30s ' "$attribute"
sudo cat "/sys/devices/system/cpu/cpufreq/policy0/$attribute" 2>/dev/null || echo unsupported
done
A Thelio Astra uses the cppc_cpufreq driver. It exposes a range from 1000000 kHz to 2200000 kHz and supports the following governors:
conservative ondemand userspace powersave performance schedutil
You’ll compare the powersave, schedutil, and performance governors.
The boost attribute reports 0 because Arm Neoverse server CPUs maintain sustained performance across the full frequency range rather than using a temporary boost mode above the configured maximum.
View a summary with cpupower
The cpupower utility provides a concise view of the same CPUFreq information.
Display the frequency information for the current CPU:
cpupower frequency-info
The output summarizes the driver, governor, frequency range, and hardware limits in one view:
analyzing CPU 43:
driver: cppc_cpufreq
CPUs which run at the same hardware frequency: 43
CPUs which need to have their frequency coordinated by software: 43
maximum transition latency: Cannot determine or is not supported.
hardware limits: 1000 MHz - 2.20 GHz
available cpufreq governors: conservative ondemand userspace powersave performance schedutil
current policy: frequency should be within 1000 MHz and 2.20 GHz.
The governor "schedutil" may decide which speed to use
within this range.
current CPU frequency: 1.44 GHz (asserted by call to kernel)
boost state support:
Active: no
The CPU number in the first line depends on which CPU the cpupower process was scheduled on. The number varies between runs.
Show the same summary for all CPUs:
cpupower -c all frequency-info
The workload and telemetry scripts read and write sysfs files directly. The cpupower output is useful for quick checks between experiments.
Locate the hwmon devices
The Linux hardware monitoring subsystem (hwmon) exposes sensor data such as power, temperature, and fan speed through sysfs. Each hardware monitoring chip or driver registers as a separate hwmon device.
The hwmon directory numbers can change after a kernel update or reboot. Identify devices by reading their name files:
for device in /sys/class/hwmon/hwmon*; do
printf '%s: ' "$device"
cat "$device/name"
done
The output on a Thelio Astra includes:
/sys/class/hwmon/hwmon0: nvme
/sys/class/hwmon/hwmon1: apm_xgene
/sys/class/hwmon/hwmon2: system76_thelio_io
/sys/class/hwmon/hwmon3: hidpp_battery_0
The device names might vary on your system. Each device provides different sensor data:
| Device | Description |
nvme | NVMe storage drive temperature |
apm_xgene | Processor power and temperature sensors |
system76_thelio_io | System76 chassis controller for fan speed and pulse-width modulation |
hidpp_battery_0 | Logitech wireless peripheral battery level |
Print the available labels and values:
if [ "$(cat "$device/name" 2>/dev/null)" = "apm_xgene" ]; then
grep . "$device"/power*_label "$device"/power*_input \
"$device"/temp*_label "$device"/temp*_input
fi
done
/sys/class/hwmon/hwmon1/power1_label:CPU power
/sys/class/hwmon/hwmon1/power2_label:IO power
/sys/class/hwmon/hwmon1/power1_input:12200000
/sys/class/hwmon/hwmon1/power2_input:8025000
/sys/class/hwmon/hwmon1/temp1_label:SoC Temperature
/sys/class/hwmon/hwmon1/temp1_input:37000
Each sensor has a _label file that describes what it measures, and a corresponding _input file that holds the current reading. The naming convention uses a type prefix (power or temp) followed by a channel number. The hwmon subsystem reports power in microwatts and temperature in millidegrees Celsius.
The sample values can be converted to watts and Celsius as follows:
| File | Raw value | Converted value |
power1_input (CPU power) | 12200000 µW | 12.2 W |
power2_input (I/O power) | 8025000 µW | 8.025 W |
temp1_input (SoC Temperature) | 37000 m°C | 37°C |
SoC power is the sum of CPU and I/O power. It doesn’t represent total system or wall power because it excludes memory, storage, fans, and power-supply losses.
Inspect fan telemetry
The System76 Thelio I/O controller on a Thelio Astra exposes fan speed and pulse-width modulation (PWM) values.
The following loop prints the labels and current readings for fan telemetry. Replace system76_thelio_io with the controller that exposes fan telemetry on your system:
if [ "$(cat "$device/name" 2>/dev/null)" = "system76_thelio_io" ]; then
grep . "$device"/fan*_label "$device"/fan*_input "$device"/pwm*
fi
done
The output is similar to:
/sys/class/hwmon/hwmon2/fan1_label:CPU Fan
/sys/class/hwmon/hwmon2/fan2_label:Intake Fan
/sys/class/hwmon/hwmon2/fan3_label:GPU Fan
/sys/class/hwmon/hwmon2/fan4_label:Aux Fan
/sys/class/hwmon/hwmon2/fan1_input:1065
/sys/class/hwmon/hwmon2/fan2_input:735
/sys/class/hwmon/hwmon2/fan3_input:0
/sys/class/hwmon/hwmon2/fan4_input:0
/sys/class/hwmon/hwmon2/pwm1:85
/sys/class/hwmon/hwmon2/pwm2:85
/sys/class/hwmon/hwmon2/pwm3:85
/sys/class/hwmon/hwmon2/pwm4:85
The fan*_label files identify each fan header on the chassis. The fan*_input files report the current speed in RPM. A value of 0 means the fan is either not connected or not spinning.
The pwm* files control fan duty cycle on a scale from 0 (off) to 255 (full speed). A value of 85 corresponds to about 33% duty cycle. The chassis firmware manages PWM automatically based on temperature.
CPU fan and intake fan RPM are recorded as secondary telemetry. The GPU and auxiliary fans aren’t connected on this system.
Record fan speed during each experiment, but leave the fan policy unchanged. Changing frequency and fan control at the same time makes it difficult to identify which setting caused a temperature or performance difference.
Check whether the sensors update
Read the processor sensors once per second for 10 seconds:
sensor_dir=$(for device in /sys/class/hwmon/hwmon*; do
echo "$device"
break
fi
done)
printf '%s %s %s %s\n' "timestamp" "cpu_power_uw" "io_power_uw" "soc_temp_mc"
for sample in $(seq 1 10); do
printf '%s ' "$(date --iso-8601=seconds)"
grep -h . "$sensor_dir"/power*_input "$sensor_dir"/temp*_input | xargs
sleep 1
done
Each row prints a timestamp followed by three raw sensor values: CPU power in microwatts, I/O power in microwatts, and SoC temperature in millidegrees Celsius.
timestamp cpu_power_uw io_power_uw soc_temp_mc
2025-06-15T10:30:01+00:00 12200000 8025000 37000
2025-06-15T10:30:02+00:00 12350000 8010000 37000
2025-06-15T10:30:03+00:00 12180000 8030000 37500
The values should change as background activity changes. A sensor that never updates isn’t suitable for measuring workload energy.
You’ve now identified the CPU frequency policies and the CPU power, I/O power, SoC temperature, and fan sensors.
Next, you’ll create a logger that reads these values while OpenSSL runs.
