Measure and compare performance per watt on an Arm Linux system
Prepare the Arm Linux system
Discover CPU frequency and power controls
Collect synchronized power and thermal telemetry
Establish an OpenSSL performance and power baseline
Compare Linux CPU frequency governors
Compare CPU maximum-frequency limits
Calculate performance and energy efficiency
Create a governor configuration script
The governor experiment keeps the hardware minimum and maximum frequency limits unchanged. Only the governor changes between runs.
Create set-governor.sh:
cat > set-governor.sh <<'EOF'
#!/usr/bin/env bash
set -eu
governor=${1:?Usage: $0 GOVERNOR}
for policy in /sys/devices/system/cpu/cpufreq/policy*; do
if ! grep -qw "$governor" "$policy/scaling_available_governors"; then
echo "$governor is not available for $(basename "$policy")" >&2
exit 1
fi
done
hardware_max=$(cat "$policy/cpuinfo_max_freq")
hardware_min=$(cat "$policy/cpuinfo_min_freq")
echo "$hardware_max" | sudo tee "$policy/scaling_max_freq" > /dev/null
echo "$hardware_min" | sudo tee "$policy/scaling_min_freq" > /dev/null
echo "$governor" | sudo tee "$policy/scaling_governor" > /dev/null
done
echo "Configured all CPUFreq policies with the $governor governor"
EOF
chmod +x set-governor.sh
The script restores the full hardware frequency range before applying the governor. This prevents a frequency cap from an earlier experiment affecting the result.
Run the powersave test
Configure the powersave governor and verify that all policies changed:
sudo ./set-governor.sh powersave
grep -h . /sys/devices/system/cpu/cpufreq/policy*/scaling_governor | sort -u
The expected output is:
powersave
Allow the system to settle, then run OpenSSL:
sleep 60
sudo ./run-openssl.sh governor-powersave 90
Run the schedutil test
Configure schedutil and run the same workload:
sudo ./set-governor.sh schedutil
sleep 60
sudo ./run-openssl.sh governor-schedutil 90
This run repeats the baseline configuration. Keeping it in the governor sequence makes it easier to compare runs collected close together under similar room and system conditions.
Run the performance test
Configure performance and run the workload:
sudo ./set-governor.sh performance
sleep 60
sudo ./run-openssl.sh governor-performance 90
Inspect the frequency traces
Print the minimum, average, and maximum observed frequency for each run:
for csv in results/governor-*/telemetry.csv; do
awk -F, '
NR == 2 { min = max = $3 }
NR > 1 {
total += $3
count++
if ($3 < min) min = $3
if ($3 > max) max = $3
END {
printf "%s min=%.0f avg=%.0f max=%.0f kHz\n", FILENAME, min, total / count, max
' "$csv"
done
The performance governor should request the highest permitted performance. The powersave governor should request the lowest permitted performance. The schedutil governor adjusts the request according to scheduler utilization.
Check the measured frequency instead of assuming each governor behaved as expected. Firmware, platform controls, and thermal limits can affect the actual frequency.
Restore the default configuration
Return to the original settings after the governor tests:
./restore-cpufreq.sh
You’ve now collected equivalent workload and telemetry data for three governors while preserving the full frequency range.
Next, you’ll keep schedutil fixed and change only the maximum permitted frequency.
