Create a frequency-cap script
The frequency-cap experiment uses the schedutil governor for every run. The hardware minimum remains unchanged, and the maximum frequency is the only variable.
Create set-frequency-cap.sh:
cat > set-frequency-cap.sh <<'EOF'
#!/usr/bin/env bash
set -eu
target_max=${1:?Usage: $0 MAX_FREQUENCY_KHZ}
case "$target_max" in
    *[!0-9]*|'')
        echo "Frequency must be an integer in kHz" >&2
        exit 1
esac
for policy in /sys/devices/system/cpu/cpufreq/policy*; do
    hardware_min=$(cat "$policy/cpuinfo_min_freq")
    hardware_max=$(cat "$policy/cpuinfo_max_freq")
    if [ "$target_max" -lt "$hardware_min" ] || [ "$target_max" -gt "$hardware_max" ]; then
        echo "$target_max is outside the range $hardware_min-$hardware_max for $(basename "$policy")" >&2
        exit 1
    fi
done
    echo "$hardware_min" | sudo tee "$policy/scaling_min_freq" > /dev/null
    echo "$target_max" | sudo tee "$policy/scaling_max_freq" > /dev/null
    echo schedutil | sudo tee "$policy/scaling_governor" > /dev/null
done
echo "Configured schedutil with a maximum frequency of $target_max kHz"
EOF
chmod +x set-frequency-cap.sh
The Thelio Astra example accepts maximum limits between 1000000 kHz and 2200000 kHz. Other systems can expose a different range.
Verify an intermediate limit
Apply a 1400000 kHz maximum:
sudo ./set-frequency-cap.sh 1400000
Confirm that every policy accepted the limit:
grep -h . /sys/devices/system/cpu/cpufreq/policy*/scaling_max_freq \
    | sort -nu
The expected output is:
        1400000
If Linux rounds or rejects the value, select an accepted value within the hardware range and use that value consistently in the remaining steps.
Run the capped-frequency tests
Run the workload at a 1400000 kHz maximum:
sleep 60
sudo ./run-openssl.sh cap-1400mhz 90
Apply an 1800000 kHz maximum and run the same workload:
sudo ./set-frequency-cap.sh 1800000
sleep 60
sudo ./run-openssl.sh cap-1800mhz 90
Apply the full 2200000 kHz maximum and run the final capped-frequency test:
sudo ./set-frequency-cap.sh 2200000
sleep 60
sudo ./run-openssl.sh cap-2200mhz 90
The cap-2200mhz run uses the same limits as the baseline schedutil run. The duplicate measurement helps identify normal run-to-run variation.
Keep the comparison controlled
Use the same conditions for every run:
  • Keep the OpenSSL command, worker count, duration, and buffer size unchanged
  • Close unrelated CPU-intensive applications
  • Leave the fan policy unchanged
  • Use the same minimum frequency and governor
  • Allow the same idle period before every run
  • Keep the system connected to the same power and cooling environment
A single run is sufficient to complete the workflow and check whether the efficiency curves differ. For best results, repeat each configuration at least three times and note the median.
Restore the original settings
Restore the CPUFreq settings that you saved when you prepared the system:
./restore-cpufreq.sh
Verify the restored governor and limits:
grep . /sys/devices/system/cpu/cpufreq/policy0/{scaling_governor,scaling_min_freq,scaling_max_freq}
The output is similar to:
        /sys/devices/system/cpu/cpufreq/policy0/scaling_governor:schedutil
/sys/devices/system/cpu/cpufreq/policy0/scaling_min_freq:1000000
/sys/devices/system/cpu/cpufreq/policy0/scaling_max_freq:2200000
You’ve now collected OpenSSL and telemetry results under three maximum-frequency limits while keeping the governor fixed.
Next, you’ll calculate average power, energy, throughput per watt, and joules per gigabyte.
