Create the telemetry logger
The logger finds hwmon devices and channels by name and label. The use of both name and label keeps the script working if Linux assigns different hwmon directory numbers after a reboot.
Create collect-telemetry.sh in ~/perf-per-watt, replacing ampere_hwmon and thelio_hwmon with the devices for your system:
cat > collect-telemetry.sh <<'EOF'
#!/usr/bin/env bash
set -eu
output_file=${1:-telemetry.csv}
interval=${2:-1}
find_hwmon() {
    wanted_name=$1
    for device in /sys/class/hwmon/hwmon*; do
        if [ "$(cat "$device/name" 2>/dev/null)" = "$wanted_name" ]; then
            echo "$device"
            return 0
        fi
    done
    return 1
find_labeled_input() {
    directory=$1
    sensor_type=$2
    wanted_label=$3
    for label_file in "$directory"/"$sensor_type"*_label; do
        [ -e "$label_file" ] || continue
        if [ "$(cat "$label_file")" = "$wanted_label" ]; then
            echo "${label_file%_label}_input"
            return 0
        fi
    done
    return 1
to_watts() {
    awk -v value="$1" 'BEGIN { printf "%.6f", value / 1000000 }'
to_celsius() {
    awk -v value="$1" 'BEGIN { printf "%.3f", value / 1000 }'
ampere_hwmon=$(find_hwmon apm_xgene) || {
    echo "The apm_xgene hwmon device was not found" >&2
    exit 1
thelio_hwmon=$(find_hwmon system76_thelio_io) || {
    echo "The system76_thelio_io hwmon device was not found" >&2
    exit 1
cpu_power_file=$(find_labeled_input "$ampere_hwmon" power "CPU power")
io_power_file=$(find_labeled_input "$ampere_hwmon" power "IO power")
soc_temp_file=$(find_labeled_input "$ampere_hwmon" temp "SoC Temperature")
cpu_fan_file=$(find_labeled_input "$thelio_hwmon" fan "CPU Fan")
intake_fan_file=$(find_labeled_input "$thelio_hwmon" fan "Intake Fan")
printf '%s\n' \
    'timestamp,epoch_seconds,avg_freq_khz,cpu_power_w,io_power_w,soc_power_w,soc_temp_c,cpu_fan_rpm,intake_fan_rpm' \
    > "$output_file"
while true; do
    timestamp=$(date --iso-8601=seconds)
    epoch_seconds=$(date +%s.%N)
    avg_freq_khz=$(awk '
        { total += $1; count++ }
        END {
            if (count > 0) {
                printf "%.0f", total / count
            } else {
                print "0"
    ' /sys/devices/system/cpu/cpufreq/policy*/cpuinfo_cur_freq)
    cpu_power_w=$(to_watts "$(cat "$cpu_power_file")")
    io_power_w=$(to_watts "$(cat "$io_power_file")")
    soc_power_w=$(awk -v cpu="$cpu_power_w" -v io="$io_power_w" \
        'BEGIN { printf "%.6f", cpu + io }')
    soc_temp_c=$(to_celsius "$(cat "$soc_temp_file")")
    cpu_fan_rpm=$(cat "$cpu_fan_file")
    intake_fan_rpm=$(cat "$intake_fan_file")
    printf '%s,%s,%s,%s,%s,%s,%s,%s,%s\n' \
        "$timestamp" \
        "$epoch_seconds" \
        "$avg_freq_khz" \
        "$cpu_power_w" \
        "$io_power_w" \
        "$soc_power_w" \
        "$soc_temp_c" \
        "$cpu_fan_rpm" \
        "$intake_fan_rpm" \
        >> "$output_file"
    sleep "$interval"
done
EOF
chmod +x collect-telemetry.sh
The script samples every second by default. One-second sampling captures sustained changes without spending excessive time reading sysfs files.
Test the logger
Start the logger in the background, collect five samples, and stop it:
sudo ./collect-telemetry.sh telemetry-test.csv &
logger_pid=$!
sleep 5
sudo kill "$logger_pid"
wait "$logger_pid" 2>/dev/null || true
Inspect the first records:
head telemetry-test.csv
The output is similar to:
2026-08-06T09:47:56-05:00,1786027676.633482916,1109099,12.240000,8.025000,20.265000,36.000,1065,720
2026-08-06T09:47:57-05:00,1786027677.708797530,1031262,12.280000,8.024000,20.304000,36.000,1065,735
2026-08-06T09:47:58-05:00,1786027678.783871620,1018438,12.360000,8.024000,20.384000,36.000,1065,735
2026-08-06T09:47:59-05:00,1786027679.863988207,1025325,12.360000,8.025000,20.385000,36.000,1065,720
2026-08-06T09:48:00-05:00,1786027680.940551795,1006262,12.360000,8.025000,20.385000,36.000,1065,735
Your values will differ. Confirm that each row has nine fields and that power, temperature, and fan readings are nonzero.
Count the number of fields in each row:
awk -F, 'NF != 9 { print "Unexpected field count on line", NR, ":", NF }' telemetry-test.csv
No output means every row has the expected number of fields.
Interpret the recorded values
The logger records the following values:
ColumnMeaning
avg_freq_khzMean current frequency across CPUFreq policies
cpu_power_wCPU-domain power reported by temperature and power sensors
io_power_wI/O-domain power reported by temperature and power sensors
soc_power_wSum of CPU and I/O power
soc_temp_cSoC temperature
cpu_fan_rpmCPU fan speed
intake_fan_rpmChassis intake fan speed
The average frequency is a system-wide summary. It doesn’t show whether individual CPUs run at different frequencies, but it’s sufficient for comparing OpenSSL runs using all cores.
You’ve now created and tested a CSV telemetry logger.
Next, run OpenSSL while the logger records frequency, power, temperature, and fan speed.
