# Deploy OpenStack on an Azure Arm VM with Kolla-Ansible
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openstack-on-azure/)
- [Understand Azure Cobalt 100 and OpenStack](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openstack-on-azure/background/)
- [Create an Azure Cobalt 100 Arm64 virtual machine for DevStack](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openstack-on-azure/instance/)
- [Deploy OpenStack on Azure Cobalt 100 with DevStack](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openstack-on-azure/devtstack-deployment/)
- [Prepare Azure Arm64 virtual machine for Kolla-Ansible](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openstack-on-azure/prepare-vm-for-kolla-ansible/)
- [Deploy OpenStack on an Azure Arm VM with Kolla-Ansible](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openstack-on-azure/kolla-ansible-deployment/)
- [Validate OpenStack and launch a VM on Azure Cobalt 100](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openstack-on-azure/validation-vm-launch/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openstack-on-azure/_next-steps/)
In this section, you’ll deploy OpenStack using Kolla-Ansible on the Azure Ubuntu 24.04 Arm64 virtual machine (VM) that you created in the previous section.
Kolla-Ansible deploys OpenStack services as Docker containers, making the deployment modular, reproducible, and easier to manage.
After completing this guide, your environment will run core OpenStack services such as Nova, Neutron, Keystone, and Glance. The environment will support Arm64 (`aarch64`) architecture, provide CLI and Horizon access, and allow launching VMs.
> **Warning:** You can’t run DevStack and Kolla-Ansible on the same VM at the same time. Use separate VMs for each approach. If you run both on the same host, port conflicts will cause deployment failures.
## Configure an external network interface
Configure an external network interface to ensure that OpenStack can use `eth1` as the external/provider network:
```bash
sudo ip addr flush dev eth1
sudo ip link set eth1 up
## Install system dependencies
Install packages for Python builds and OpenStack dependencies:
```bash
sudo apt update
sudo apt install -y \
python3-venv python3-dev python3-pip \
gcc libffi-dev libssl-dev \
libdbus-1-dev libglib2.0-dev pkg-config \
meson ninja-build curl
## Install Docker
Install Docker to run all OpenStack services as containers:
```bash
sudo apt install -y docker.io
sudo systemctl enable docker
sudo systemctl start docker
Add user to Docker group:
```bash
sudo usermod -aG docker $USER
Apply group permissions:
```bash
newgrp docker
> **Warning:** Without applying group permissions, Docker commands will fail with a permission error.
Verify Docker installation:
```bash
docker run hello-world
## Create Python virtual environment
To isolate dependencies required for Kolla-Ansible, create a virtual environment:
```bash
python3 -m venv ~/kolla-venv
source ~/kolla-venv/bin/activate
## Install Kolla-Ansible and dependencies
Install the following tools to deploy and manage OpenStack services:
```bash
pip install -U pip
pip install \
'ansible-core>=2.15,<2.17' \
kolla-ansible \
docker \
dbus-python
ansible-galaxy collection install openstack.kolla
kolla-ansible install-deps
## Configure Kolla
Copy the default configuration files and inventory into place:
```bash
sudo mkdir -p /etc/kolla
sudo chown $USER:$USER /etc/kolla
cp -r ~/kolla-venv/share/kolla-ansible/etc_examples/kolla/* /etc/kolla
cp ~/kolla-venv/share/kolla-ansible/ansible/inventory/all-in-one .
## Edit globals.yml
Edit the configuration in `globals.yml`:
```bash
vi /etc/kolla/globals.yml
```yaml
kolla_base_distro: "debian"
openstack_tag_suffix: "-aarch64"
network_interface: "eth0"
neutron_external_interface: "eth1"
kolla_internal_vip_address: "127.0.0.1"
enable_keepalived: "no"
nova_compute_virt_type: "qemu"
The following are some of the key configuration choices:
- `kolla_base_distro: "debian"` — ensures Arm-compatible container images are available
- `openstack_tag_suffix: "-aarch64"` — ensures the correct image variant is selected
- `kolla_internal_vip_address: "127.0.0.1"` — avoids Azure networking issues on single-node deployments
- `enable_keepalived: "no"` — required for single-node deployments
- `nova_compute_virt_type: "qemu"` — ensures Nova uses QEMU (Quick Emulator) on Arm VMs where KVM (Kernel-based Virtual Machine) is unavailable
## Configure Nova
Arm-based Azure VMs don’t support KVM virtualization. Update the configuration for Nova:
```bash
sudo mkdir -p /etc/kolla/config
cat <<EOF | sudo tee /etc/kolla/config/nova.conf
[libvirt]
virt_type = qemu
cpu_mode = none
EOF
Setting `virt_type = qemu` and `cpu_mode = none` ensures Nova uses QEMU emulation, which works on Arm VMs where KVM is unavailable. Kolla deploys libvirt inside its own `nova_libvirt` container and manages the connection URI automatically.
## Generate passwords
Create all required passwords for OpenStack services:
```bash
kolla-genpwd
## Deploy OpenStack
The deployment runs in five stages. Each stage must complete successfully before the next one starts.
| Stage      | Command                    | What it does                                          |
| Bootstrap  | `bootstrap-servers`        | Configures the host: Docker users, directories, and system settings |
| Prechecks  | `prechecks`                | Validates that the environment meets all requirements |
| Pull       | `pull`                     | Downloads OpenStack container images from the registry |
| Deploy     | `deploy`                   | Starts all OpenStack service containers               |
| Post-deploy| `post-deploy`              | Generates admin credentials and writes `admin-openrc.sh` |
Run each command and wait for it to complete before proceeding. Start by running the bootstrap command:
```bash
kolla-ansible bootstrap-servers -i all-in-one
The output is similar to:
```plaintext
__output__
PLAY RECAP ***************************************************************************************************************************
__output__
localhost                  : ok=41   changed=13   unreachable=0    failed=0    skipped=30   rescued=0    ignored=0
> **Note:** Kolla-Ansible modifies Docker’s systemd unit files during bootstrap. If Docker is already running, the service can fail with the following error:
```plaintext
RUNNING HANDLER [openstack.kolla.docker : Restart docker]
fatal: [localhost]: FAILED! => {"changed": false, "msg": "Unable to start service docker: Job for docker.service failed because the control process exited with error code.\nSee \"systemctl status docker.service\" and \"journalctl -xeu docker.service\" for details.\n"}
Run these three commands to recover:
```bash
sudo systemctl daemon-reload
sudo systemctl reset-failed docker.socket docker.service
sudo systemctl restart docker
`daemon-reload` picks up the updated unit files written by Kolla-Ansible. `reset-failed` clears the failed state that was blocking the restart. `restart docker` starts Docker cleanly.
After Docker is running, re-run the bootstrap step.
After running bootstrap successfully, run:
```bash
kolla-ansible prechecks -i all-in-one
```plaintext
__output__
__output__
localhost                  : ok=96   changed=0    unreachable=0    failed=0    skipped=142  rescued=0    ignored=0
> **Note:** Kolla-Ansible manages libvirt inside its own `nova_libvirt` container. If host `libvirtd` is running, prechecks will fail with:
```plaintext
TASK [nova-cell : Checking that host libvirt is not running]
To fix this, stop and disable the host libvirt service before running prechecks:
```bash
sudo systemctl stop libvirtd 2>/dev/null || true
sudo systemctl disable libvirtd 2>/dev/null || true
sudo rm -f /var/run/libvirt/libvirt-sock
Then, re-run prechecks.
After running prechecks successfully, run:
```bash
kolla-ansible pull -i all-in-one
```plaintext
__output__
PLAY [Apply role skyline] ************************************************************************************************************
__output__
skipping: no hosts matched
__output__
__output__
__output__
localhost                  : ok=33   changed=14   unreachable=0    failed=0    skipped=52   rescued=0    ignored=0
After running pull successfully, run:
```bash
kolla-ansible deploy -i all-in-one
```plaintext
__output__
__output__
__output__
__output__
__output__
localhost                  : ok=368  changed=34   unreachable=0    failed=0    skipped=267  rescued=0    ignored=0
The deploy step starts all OpenStack service containers. It takes the longest of the five stages — allow 20 to 30 minutes.
After running deploy, run:
```bash
kolla-ansible post-deploy -i all-in-one
## Install the OpenStack client and load credentials
The OpenStack CLI is not included in Kolla-Ansible. Install it inside the virtual environment, then load the admin credentials that `post-deploy` generated:
```bash
pip install python-openstackclient
source /etc/kolla/admin-openrc.sh
## Verify services
Confirm that all Nova compute services are running:
```bash
openstack compute service list
```plaintext
__output__
__output__
| ID                                   | Binary         | Host         | Zone     | Status  | State | Updated At                 |
__output__
__output__
| bcb60746-4219-44a7-b850-5f9b28ec12d7 | nova-scheduler | ansible-d8ps | internal | enabled | up    | 2026-04-14T07:38:13.000000 |
__output__
| 2054f4ad-2492-46e4-990a-4fdf7d40e20f | nova-conductor | ansible-d8ps | internal | enabled | up    | 2026-04-14T07:38:11.000000 |
__output__
| b0d28456-483b-4a9c-bcaf-5932364e32b6 | nova-compute   | ansible-d8ps | nova     | enabled | up    | 2026-04-14T07:38:16.000000 |
__output__
Confirm all Neutron network agents are running successfully:
```bash
openstack network agent list
```plaintext
__output__
__output__
| ID                     | Agent Type         | Host         | Availability Zone | Alive | State | Binary                   |
__output__
__output__
| 0ac15427-97e0-4690-    | Metadata agent     | ansible-d8ps | None              | :-)   | UP    | neutron-metadata-agent   |
__output__
| be2b-ac3b236a331f      |                    |              |                   |       |       |                          |
__output__
| 41dc2dee-106e-4a99-    | DHCP agent         | ansible-d8ps | nova              | :-)   | UP    | neutron-dhcp-agent       |
__output__
| 8e7b-94b8fac38fe1      |                    |              |                   |       |       |                          |
__output__
| f36a8827-ee1f-4387-    | L3 agent           | ansible-d8ps | nova              | :-)   | UP    | neutron-l3-agent         |
__output__
| 9c11-bdbb0c10dee4      |                    |              |                   |       |       |                          |
__output__
| fb0f81ce-06e1-4ded-    | Open vSwitch agent | ansible-d8ps | None              | :-)   | UP    | neutron-openvswitch-agent |
__output__
| b736-1bd329a3a59e      |                    |              |                   |       |       | agent                    |
__output__
All services should show `enabled` and state `up`. If any service shows `down`, check the container logs with `docker logs <container_name>`.
## What you’ve accomplished and what’s next
In this section, you deployed OpenStack using Kolla-Ansible on an Azure Cobalt 100 Arm64 VM. The deployment ran all OpenStack services as Docker containers, including Nova, Neutron, Keystone, Glance, and Horizon.
Your environment is now ready to launch and manage virtual machines. In the next section, you’ll validate the OpenStack deployment and launch a test VM instance.
