Deploy OpenStack on Arm64 virtual machines on Azure Cobalt 100
Understand Azure Cobalt 100 and OpenStack
Create an Azure Cobalt 100 Arm64 virtual machine for DevStack
Deploy OpenStack on Azure Cobalt 100 with DevStack
Prepare Azure Arm64 virtual machine for Kolla-Ansible
Deploy OpenStack on an Azure Arm VM with Kolla-Ansible
Validate OpenStack and launch a VM on Azure Cobalt 100
Use a single-NIC
D4ps_v6 instance with at least 80 GB of disk. You don’t need an extra NIC or a separate data disk for DevStack.Use separate Azure VMs for DevStack and Kolla-Ansible.
Use DevStack for a script-based, single-node environment aimed at development and testing. Choose Kolla-Ansible to deploy OpenStack services as containers for a modular, reproducible, production-like setup.
Provision at least 4 vCPUs (8 recommended), 16 GB RAM, a 100 GB OS disk, and a 32 GB data disk for Cinder/Docker on Ubuntu 24.04. Use two NICs:
eth0 for management and eth1 for external networking.For DevStack, expect a single node running Keystone, Nova, Glance, and Horizon. Verify access using the CLI and Horizon. For Kolla-Ansible, confirm that core services such as Nova, Neutron, Keystone, and Glance are running in containers. Ensure that you can access the CLI and Horizon to launch instances.
