# Measure performance improvements with a microbenchmark
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openrng-with-performix/)
- [Set up your environment](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openrng-with-performix/how-to-1/)
- [Run the baseline data-processing example](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openrng-with-performix/how-to-2/)
- [Identify code hotspots with Arm Performix](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openrng-with-performix/how-to-3/)
- [Accelerate distribution generation with OpenRNG](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openrng-with-performix/how-to-4/)
- [Measure performance improvements with a microbenchmark](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openrng-with-performix/how-to-5/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openrng-with-performix/_next-steps/)
## Run the microbenchmark sweep
The microbenchmark in `tests/sweep-microbenchmark.cpp` isolates the `generateDistribution` function and times it across eight input sizes, from 2^8 to 2^15 elements (256 to 32,768 points). Each run generates the sum of two distributions and records the elapsed time in microseconds using a scoped timer. By running both the baseline build and the accelerated build across this range, you can see how the speedup from OpenRNG scales with data size.
Run the microbenchmark sweep to configure and build the baseline and accelerated benchmarks:
make clean
cmake -S . -B build-baseline -DBUILD_TESTS=ON
cmake -S . -B build-apl -DBUILD_TESTS=ON -DUSE_APL=ON
cmake --build build-baseline --target sweep_microbench_baseline
cmake --build build-apl --target sweep_microbench_with_apl
Run the baseline benchmark first:
./build-baseline/tests/sweep_microbench_baseline
The output shows elapsed time in microseconds for each input size, and is similar to:
__output__Generating Distribution of size 256 = 174 us
__output__Generating Distribution of size 512 = 280 us
__output__Generating Distribution of size 1024 = 554 us
__output__Generating Distribution of size 2048 = 1117 us
__output__Generating Distribution of size 4096 = 2231 us
__output__Generating Distribution of size 8192 = 4429 us
__output__Generating Distribution of size 16384 = 8908 us
__output__Generating Distribution of size 32768 = 17818 us
Then run the accelerated benchmark:
./build-apl/tests/sweep_microbench_with_apl
The output shows the accelerated times across the same input sizes, and is similar to:
__output__Generating Distribution of size 256 = 58 us
__output__Generating Distribution of size 512 = 59 us
__output__Generating Distribution of size 1024 = 102 us
__output__Generating Distribution of size 2048 = 186 us
__output__Generating Distribution of size 4096 = 370 us
__output__Generating Distribution of size 8192 = 709 us
__output__Generating Distribution of size 16384 = 1431 us
__output__Generating Distribution of size 32768 = 2785 us
The observed speedup of the `generateDistribution` function varies with distribution size, showing smaller gains at lower data sizes and larger gains as size grows. This indicates when Arm Performance Libraries are likely to provide meaningful performance improvements for a given application.
## What you’ve accomplished
You completed a full profile-first optimization workflow on Arm. Starting from a baseline C++ workload, you used Arm Performix Code Hotspots to find the highest-cost function, then replaced it with OpenRNG and Arm Performance Libraries. The microbenchmark confirmed that the speedup scales with data size, giving you a repeatable method for identifying and targeting bottlenecks in your Arm workloads.
