# Accelerate distribution generation with OpenRNG
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openrng-with-performix/)
- [Set up your environment](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openrng-with-performix/how-to-1/)
- [Run the baseline data-processing example](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openrng-with-performix/how-to-2/)
- [Identify code hotspots with Arm Performix](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openrng-with-performix/how-to-3/)
- [Accelerate distribution generation with OpenRNG](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openrng-with-performix/how-to-4/)
- [Measure performance improvements with a microbenchmark](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openrng-with-performix/how-to-5/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openrng-with-performix/_next-steps/)
## Understand OpenRNG and Arm Performance Libraries
Arm Performance Libraries include numerical routines tuned for Arm processors. These Arm-tuned routines can speed up execution by reducing overhead and improving throughput for compute-heavy kernels.
OpenRNG is the random-number component in Arm Performance Libraries. It exposes a Vector Statistical Library (VSL) API, where *VSL* means generating distributions in vector form (many values per call) instead of one sample at a time.
You’ll use this vector API to generate Gaussian values in bulk. Bulk generation through a stream object lowers per-sample overhead, which is why this change can reduce runtime in the hotspot.
OpenRNG is API-compatible with the Intel oneMKL VSL RNG interface, so distribution call sites remain familiar when you move between `x86` and `aarch64` builds. You mainly switch build configuration, not workload logic. For more information, see the [OpenRNG developer reference guide](https://developer.arm.com/documentation/101004/2601/Open-Random-Number-Generation-Reference-Guide/RNG-Introduction/An-overview-of-OpenRNG?lang=en).
In `src/vec1d.cpp`, the `USE_ARMPL` macro controls which implementation is compiled. In this project, enabling `USE_ARMPL` selects the `aarch64` OpenRNG path:
```cpp
#if USE_ARMPL
    #if defined(__aarch64__)
        #include <amath.h>
        #include <openrng.h>
    #else
        #error "USE_ARMPL enabled but not on AArch64"
    #endif
#endif
The OpenRNG path creates one VSL stream and fills a contiguous buffer for both coordinates. `count` is `2 * v.getSize()` because each point has `x` and `y` values:
```cpp
VSLStreamStatePtr stream;
vslNewStream(&stream, VSL_BRNG_SFMT19937, 777);
const int count = 2 * v.getSize();
std::vector<float> tmp(count);
For Gaussian generation, the code calls the single-precision VSL routine `vsRngGaussian`. Here, `param_a` is the mean and `param_b` is the standard deviation:
```cpp
vsRngGaussian(
    VSL_RNG_METHOD_UNIFORM_STD,
    stream,
    count,
    tmp.data(),
    param_a, // mean
    param_b  // standard deviation
After bulk generation, values are mapped back into your `Point` vector:
```cpp
auto& data = v.getData();
for (int i = 0; i < v.getSize(); i++){
    data[i]._x = tmp[2*i];
    data[i]._y = tmp[2*i+1];
vslDeleteStream(&stream);
## Build and run the accelerated variant
Build and run the accelerated variant by passing `-DUSE_APL=1` to enable the OpenRNG path in `vec1d.cpp`:
```bash
make clean
cmake -S . -B build -DUSE_APL=1
cmake --build build --target main_with_apl
./build/src/main_with_apl
## Analyze the flame graph
Now profile the accelerated binary in the Arm Performix GUI using `./build/src/main_with_apl` as the workload. Follow the same steps as the previous section.
![Image Alt Text:A screenshot of the Arm Performix GUI showing a Code Hotspots run configured for the accelerated executable main_with_apl. The workload, profiling duration, and sample rate settings and their values are visible](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openrng-with-performix/hotspot-with-apl.jpg)
When the run completes, Performix displays the flame graph:
![Image Alt Text:Arm Performix flame graph for the accelerated executable with split attribution for shared-library calls from the OpenRNG path](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openrng-with-performix/flame-graph-detached.jpg)
The flame graph shows `main`, but Arm Performance Libraries functions (including OpenRNG) don’t appear above it. Instead, most samples are attributed to dynamic loader functions (for example, `_dl_*`), which indicates missing symbol resolution. This often happens on Linux when pre-built shared libraries (`*.so`) don’t include debug symbols. The profiler can’t resolve internal library calls, so stacks appear truncated.
To fix this, rebuild OpenRNG from source with debug information enabled (for example, `-g`), so the library functions show up correctly above main.
Clone and build OpenRNG from the project root with debug symbols enabled:
```bash
git clone https://github.com/arm/openrng.git && cd openrng
cmake -S . -B build -DCMAKE_BUILD_TYPE=Debug -DCMAKE_INSTALL_PREFIX=$PWD/install
cmake --build build -j $(nproc -1)
cmake --install build
cd ..
From the project root, compile the debug binary:
```bash
g++ --std=c++20 -g -O0 \
  src/main.cpp src/vec1d.cpp src/point.cpp src/rectangle.cpp src/export_data.cpp \
  -DUSE_ARMPL=1 \
  -I./include \
  -I./openrng/install/include \
  -I${ARMPL_DIR}/include \
  -L./openrng/install/lib64 \
  -L${ARMPL_DIR}/lib \
  -lopenrng -lamath -lm \
  -Wl,-rpath,$PWD/openrng/install/lib64 \
  -Wl,-rpath,${ARMPL_DIR}/lib \
  -o ./build/debug_openrng
> OpenRNG uses the CMake build system. As an alternative, you can update your CMake configuration to fetch from the third-party library. The direct command is used here primarily for convenience.
From Performix, run the code hotspot recipe and target the `./build/debug_openrng` binary. When the run completes, Performix displays the flame graph:
![Image Alt Text:Arm Performix flame graph after rebuilding OpenRNG, with OpenRNG symbols correctly resolved and stacked above the calling functions](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openrng-with-performix/openrng_flame_graph_with_debug.jpg)
You can now correctly see the OpenRNG frames appearing above your calling functions. Because hotspots are identified through periodic sampling, the measurements provide limited direct insight into exact wall-clock time.
## What you’ve accomplished and what’s next
In this section, you:
- Replaced the standard library random generation path with the OpenRNG vector API from Arm Performance Libraries
- Built and ran the accelerated executable
- Profiled the accelerated binary with Arm Performix
- Resolved missing symbol attribution by rebuilding OpenRNG from source with debug symbols
Next, you’ll measure the speedup of the hot function and examine how the improvement varies across different data sizes.
