# Test PAC/BTI support with SUSE OpenJDK
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openjdk-pacbti-gcp/)
- [Learn about PAC/BTI security features and OpenJDK support](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openjdk-pacbti-gcp/background/)
- [Create a Google Cloud C4A instance](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openjdk-pacbti-gcp/instance/)
- [Test PAC/BTI support with SUSE OpenJDK](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openjdk-pacbti-gcp/jvm-testing/)
- [Test PAC/BTI support with Oracle JDK](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openjdk-pacbti-gcp/jvm-testing-2/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/openjdk-pacbti-gcp/_next-steps/)
## Validate hardware and JVM security features
In this section, you’ll install the default OpenJDK package and run a comprehensive test script to check PAC/BTI support at both the hardware level and in the JVM compiler.
## Install the default OpenJDK JVM
Install the default OpenJDK Java VM:
```bash
sudo zypper refresh
sudo zypper install -y java
Confirm the newly installed JVM:
```bash
java --version
The output is similar to:
```plaintext
__output__ openjdk 17.0.13 2024-10-15
__output__ OpenJDK Runtime Environment (build 17.0.13+11-suse-150400.3.48.2-aarch64)
__output__ OpenJDK 64-Bit Server VM (build 17.0.13+11-suse-150400.3.48.2-aarch64, mixed mode, sharing)
✅ OpenJDK 17 is now installed and ready to test.
Next, download and run a script to confirm PAC/BTI readiness in the JVM you just installed.
## Create the test script
Create a file called `test-pacbti.sh` in your SSH session and paste in the following script:
```bash
#!/usr/bin/env bash
# test-pacbti.sh
# Purpose:
#   Exercise an OpenJDK JVM on Linux/AArch64 and determine whether the
#   JVM process is running on a platform that exposes Arm Pointer
#   Authentication Code features and Branch Target Identification to
#   userspace, and whether the JVM's JIT compiler supports PAC/BTI.
# Expected results:
#   The script prints a SUMMARY block at the end with one of:
#   - FULL PAC/BTI SUPPORT:
#       Platform exposes PAC/BTI and the JVM JIT can use it.
#   - PARTIAL PAC/BTI SUPPORT:
#       Platform exposes PAC/BTI but the JVM JIT does not use it.
#   - NO PAC/BTI SUPPORT:
#       Platform does not expose PAC/BTI to userspace.
# What this tests:
#   This script does not merely inspect the host from the shell. It launches
#   a Java probe inside the target JVM. The Java process reads its own
#   /proc/self/auxv, so the HWCAP/HWCAP2 values are those visible to the JVM.
#   It also checks whether the JVM accepts -XX:UseBranchProtection=standard
#   to determine if the JIT compiler can emit PAC/BTI instructions.
# Notes:
#   - PAC and BTI are architectural/security features. On Linux/AArch64,
#     userspace should discover them through AT_HWCAP / AT_HWCAP2.
#   - This intentionally avoids "try the instruction and catch SIGILL" style
#     tests, because Linux kernel documentation says feature probing should
#     use hwcaps.
#   - Some Armv8.x systems may expose PAC and/or BTI. The solid negative
#     requested here applies to Armv8 systems that lack PAC/BTI.
# Requirements:
#   - Linux
#   - AArch64 target JVM for meaningful PAC/BTI result
#   - OpenJDK 11+ for Java source-file mode, or javac available as fallback
# Usage:
#   chmod +x test-pacbti.sh
#   ./test-pacbti.sh
# Optional:
#   JAVA=/path/to/java ./test-pacbti.sh
set -u
JAVA_BIN="${JAVA:-java}"
tmpdir="$(mktemp -d)"
cleanup() {
  rm -rf "${tmpdir}"
trap cleanup EXIT
cat >"${tmpdir}/JvmAarch64PacBtiProbe.java" <<'JAVA'
import java.io.ByteArrayOutputStream;
import java.io.FileInputStream;
import java.io.IOException;
import java.lang.management.ManagementFactory;
import java.nio.ByteBuffer;
import java.nio.ByteOrder;
import java.util.Locale;
import java.util.Map;
import java.util.TreeMap;
public final class JvmAarch64PacBtiProbe {
     * Linux auxv constants.
     * AT_HWCAP  = 16
     * AT_HWCAP2 = 26
     * Linux AArch64 hwcap bit assignments:
     *   HWCAP_PACA  = 1 << 30
     *   HWCAP_PACG  = 1 << 31
     *   HWCAP2_BTI  = 1 << 17
    private static final long AT_NULL = 0L;
    private static final long AT_HWCAP = 16L;
    private static final long AT_HWCAP2 = 26L;
    private static final long HWCAP_PACA = 1L << 30;
    private static final long HWCAP_PACG = 1L << 31;
    private static final long HWCAP2_BTI = 1L << 17;
    public static void main(String[] args) throws Exception {
        String osName = System.getProperty("os.name", "unknown");
        String osArch = System.getProperty("os.arch", "unknown");
        String vmName = System.getProperty("java.vm.name", "unknown");
        String vmVersion = System.getProperty("java.vm.version", "unknown");
        String runtimeVersion = System.getProperty("java.runtime.version", "unknown");
        System.out.println("=== JVM AArch64 PAC/BTI Probe ===");
        System.out.println("Process PID          : " + currentPid());
        System.out.println("Java VM              : " + vmName);
        System.out.println("Java VM version      : " + vmVersion);
        System.out.println("Java runtime version : " + runtimeVersion);
        System.out.println("os.name              : " + osName);
        System.out.println("os.arch              : " + osArch);
        System.out.println();
        boolean linux = osName.toLowerCase(Locale.ROOT).contains("linux");
        boolean aarch64 =
            osArch.equalsIgnoreCase("aarch64") ||
            osArch.equalsIgnoreCase("arm64");
        if (!linux) {
            System.out.println("FINAL RESULT: INCONCLUSIVE");
            System.out.println("Reason      : This probe is Linux-specific because it uses /proc/self/auxv.");
            System.exit(2);
        if (!aarch64) {
            System.out.println("Reason      : JVM is not executing as AArch64/arm64.");
            System.exit(2);
        Map<Long, Long> auxv;
        try {
            auxv = readAuxv();
        } catch (IOException ex) {
            System.out.println("Reason      : Could not read /proc/self/auxv from inside the JVM.");
            System.out.println("Exception   : " + ex);
            System.exit(2);
            return;
        long hwcap = auxv.getOrDefault(AT_HWCAP, 0L);
        long hwcap2 = auxv.getOrDefault(AT_HWCAP2, 0L);
        boolean paca = (hwcap & HWCAP_PACA) != 0;
        boolean pacg = (hwcap & HWCAP_PACG) != 0;
        boolean pac = paca || pacg;
        boolean bti = (hwcap2 & HWCAP2_BTI) != 0;
        System.out.printf("AT_HWCAP             : 0x%016x%n", hwcap);
        System.out.printf("AT_HWCAP2            : 0x%016x%n", hwcap2);
        System.out.println("Decoded AArch64 features visible to this JVM process:");
        System.out.println("  HWCAP_PACA         : " + yesNo(paca));
        System.out.println("  HWCAP_PACG         : " + yesNo(pacg));
        System.out.println("  PAC present        : " + yesNo(pac));
        System.out.println("  HWCAP2_BTI         : " + yesNo(bti));
        if (pac && bti) {
            System.out.println("FINAL RESULT: POSITIVE");
            System.out.println("Meaning     : The JVM is executing on Linux/AArch64 with PAC and BTI exposed to userspace.");
            System.exit(0);
        if (!pac && !bti) {
            System.out.println("FINAL RESULT: NEGATIVE");
            System.out.println("Meaning     : The JVM is executing on Linux/AArch64 without PAC and BTI exposed to userspace.");
            System.out.println("Expected    : This is the expected solid negative on Armv8 systems that lack PAC/BTI.");
            System.exit(1);
        System.out.println("Meaning     : Only part of the expected PAC/BTI feature set is exposed.");
        System.out.println("Detail      : PAC=" + yesNo(pac) + ", BTI=" + yesNo(bti));
        System.exit(2);
    private static String yesNo(boolean value) {
        return value ? "YES" : "NO";
    private static long currentPid() {
        try {
            return ProcessHandle.current().pid();
        } catch (Throwable ignored) {
            String name = ManagementFactory.getRuntimeMXBean().getName();
            int at = name.indexOf('@');
            if (at > 0) {
                try {
                    return Long.parseLong(name.substring(0, at));
                } catch (NumberFormatException ignoredAgain) {
                    return -1L;
            return -1L;
    private static Map<Long, Long> readAuxv() throws IOException {
        byte[] data = readAll("/proc/self/auxv");
         * On AArch64 Linux, auxv entries in a 64-bit process are pairs of
         * unsigned long values:
         *   a_type, a_val
         * Java long is signed, but bit testing is unaffected.
        if (data.length % 16 != 0) {
            throw new IOException("Unexpected auxv size for 64-bit process: " + data.length);
        ByteBuffer bb = ByteBuffer.wrap(data).order(ByteOrder.nativeOrder());
        Map<Long, Long> out = new TreeMap<>();
        while (bb.remaining() >= 16) {
            long type = bb.getLong();
            long value = bb.getLong();
            if (type == AT_NULL) {
                break;
            out.put(type, value);
        return out;
    private static byte[] readAll(String path) throws IOException {
        try (FileInputStream in = new FileInputStream(path);
             ByteArrayOutputStream out = new ByteArrayOutputStream()) {
            byte[] buf = new byte[4096];
            int n;
            while ((n = in.read(buf)) >= 0) {
                out.write(buf, 0, n);
            return out.toByteArray();
JAVA
echo "=== OpenJDK JVM PAC/BTI platform exercise ==="
echo "Using java: ${JAVA_BIN}"
echo
if ! command -v "${JAVA_BIN}" > /dev/null 2>&1; then
  echo "FINAL RESULT: INCONCLUSIVE"
  echo "Reason      : java executable not found: ${JAVA_BIN}"
  exit 2
fi
echo "--- java -version ---"
"${JAVA_BIN}" -version 2>&1
echo
echo "--- JVM branch-protection flag visibility check ---"
echo "This is informational."
JIT_PACBTI="no"
if "${JAVA_BIN}" -XX:+UnlockDiagnosticVMOptions -XX:+PrintFlagsFinal -version 2>&1 | grep -E 'UseBranchProtection|BranchProtection'; then
else
  echo "No UseBranchProtection flag printed. This can happen with older JVMs or builds that do not expose the flag."
fi
echo
echo "--- Optional runtime flag exercise: -XX:UseBranchProtection=standard ---"
echo "This should be accepted by branch-protection-aware OpenJDK builds; older builds may reject it."
if "${JAVA_BIN}" -XX:UseBranchProtection=standard -version > /tmp/jvm_pac_bti_flag_check.out 2>&1; then
  echo "Accepted: -XX:UseBranchProtection=standard"
  JIT_PACBTI="yes"
else
  echo "Not accepted or not supported by this JVM:"
  sed 's/^/  /' /tmp/jvm_pac_bti_flag_check.out
fi
rm -f /tmp/jvm_pac_bti_flag_check.out
echo
echo "--- Running in-JVM auxv probe ---"
# Prefer Java source-file mode, available in modern OpenJDK.
# Fall back to javac if needed.
"${JAVA_BIN}" "${tmpdir}/JvmAarch64PacBtiProbe.java"
rc=$?
if [ "${rc}" -ne 0 ] && [ "${rc}" -ne 1 ]; then
  if command -v javac > /dev/null 2>&1; then
    echo
    echo "Source-file mode failed or was unavailable; retrying with javac fallback..."
    javac "${tmpdir}/JvmAarch64PacBtiProbe.java" && "${JAVA_BIN}" -cp "${tmpdir}" JvmAarch64PacBtiProbe
    rc=$?
  fi
fi
echo
echo "==========================================="
echo "  SUMMARY"
if [ "${rc}" -eq 0 ]; then
  echo "  Platform PAC/BTI (hardware + kernel): YES"
else
  echo "  Platform PAC/BTI (hardware + kernel): NO"
fi
if [ "${JIT_PACBTI}" = "yes" ]; then
  echo "  JVM JIT PAC/BTI support:              YES"
else
  echo "  JVM JIT PAC/BTI support:              NO"
fi
echo
if [ "${rc}" -eq 0 ] && [ "${JIT_PACBTI}" = "yes" ]; then
  echo "  FULL PAC/BTI SUPPORT"
  echo "  The platform exposes PAC/BTI and this JVM can use it in JIT-compiled code."
  echo "  Use -XX:UseBranchProtection=standard to enable it."
elif [ "${rc}" -eq 0 ]; then
  echo "  PARTIAL PAC/BTI SUPPORT"
  echo "  The platform exposes PAC/BTI but this JVM does not use it in JIT-compiled code."
  echo "  Native libraries and the OS are still protected."
  echo "  To get full support, use a JVM built with --enable-branch-protection."
else
  echo "  NO PAC/BTI SUPPORT"
  echo "  The platform does not expose PAC/BTI to userspace."
fi
exit "${rc}"
The script runs three checks in sequence:
1. **JVM flag visibility:** queries the JVM with `-XX:+PrintFlagsFinal` to check whether this build exposes a `UseBranchProtection` flag.
2. **Branch protection flag exercise:** attempts to start the JVM with `-XX:UseBranchProtection=standard`. If accepted, the JVM was built with branch protection support and can emit PAC/BTI instructions in JIT-compiled code.
3. **Hardware capability probe:** compiles and runs a small Java class inside the JVM that reads `/proc/self/auxv` to check whether the hardware and kernel expose PAC and BTI to userspace.
After all three checks, the script prints a `SUMMARY` block that combines the results into one of three verdicts:
- **FULL PAC/BTI SUPPORT:** The platform exposes PAC/BTI and the JVM JIT can use it.
- **PARTIAL PAC/BTI SUPPORT:** The platform exposes PAC/BTI but the JVM JIT does not use it.
- **NO PAC/BTI SUPPORT:** The platform does not expose PAC/BTI.
## Run the test script
In your SSH session, run the test script to confirm PAC/BTI enablement:
```bash
chmod 755 ./test-pacbti.sh
./test-pacbti.sh
```plaintext
__output__ === OpenJDK JVM PAC/BTI platform exercise ===
__output__ Using java: java
__output__
__output__ --- java -version ---
__output__ openjdk version "17.0.13" 2024-10-15
__output__
__output__ --- JVM branch-protection flag visibility check ---
__output__ This is informational.
__output__ No UseBranchProtection flag printed. This can happen with older JVMs or builds that do not expose the flag.
__output__
__output__ --- Optional runtime flag exercise: -XX:UseBranchProtection=standard ---
__output__ This should be accepted by branch-protection-aware OpenJDK builds; older builds may reject it.
__output__ Not accepted or not supported by this JVM:
__output__   Unrecognized VM option 'UseBranchProtection=standard'
__output__   Error: Could not create the Java Virtual Machine.
__output__   Error: A fatal exception has occurred. Program will exit.
__output__
__output__ --- Running in-JVM auxv probe ---
__output__ === JVM AArch64 PAC/BTI Probe ===
__output__ Process PID          : 3523
__output__ Java VM              : OpenJDK 64-Bit Server VM
__output__ Java VM version      : 17.0.13+11-suse-150400.3.48.2-aarch64
__output__ Java runtime version : 17.0.13+11-suse-150400.3.48.2-aarch64
__output__ os.name              : Linux
__output__ os.arch              : aarch64
__output__
__output__ AT_HWCAP             : 0x00000000efffffff
__output__ AT_HWCAP2            : 0x000000000003f3ff
__output__
__output__ Decoded AArch64 features visible to this JVM process:
__output__   HWCAP_PACA         : YES
__output__   HWCAP_PACG         : YES
__output__   PAC present        : YES
__output__   HWCAP2_BTI         : YES
__output__
__output__ FINAL RESULT: POSITIVE
__output__ Meaning     : The JVM is executing on Linux/AArch64 with PAC and BTI exposed to userspace.
__output__
__output__ ===========================================
__output__   SUMMARY
__output__   Platform PAC/BTI (hardware + kernel): YES
__output__   JVM JIT PAC/BTI support:              NO
__output__
__output__   PARTIAL PAC/BTI SUPPORT
__output__   The platform exposes PAC/BTI but this JVM does not use it in JIT-compiled code.
__output__   Native libraries and the OS are still protected.
__output__   To get full support, use a JVM built with --enable-branch-protection.
## Interpret the results
The output shows you two separate things:
| Layer                      | Status                         | What it means        |
| Hardware + kernel (auxv probe) | ✅ PAC and BTI exposed        | The C4A Arm Neoverse-V2 hardware and Linux kernel advertise PAC/BTI to userspace. The SUMMARY confirms platform PAC/BTI is YES.                            |
| OS and native libraries     | ✅ Protected                   | The kernel, glibc, and other system libraries on C4A are compiled with PAC/BTI. Native code in the JVM process is already protected.                          |
| JVM JIT compiler            | ❌ Not enabled                 | The SUSE OpenJDK 17 package wasn’t built with `--enable-branch-protection`. The JIT compiler doesn’t emit PAC/BTI instructions in dynamically compiled Java code. |
The `-XX:UseBranchProtection=standard` rejection confirms the JIT limitation. This flag only exists in OpenJDK builds that were compiled from source with branch protection enabled. The SUSE-packaged JDK 17 doesn’t include this support.
## What does this mean in practice?
Your Java application runs on a PAC/BTI-capable platform, and native code paths (system libraries, the JVM’s own C++ runtime) are already protected. However, the hot Java methods that the JIT compiler turns into native machine code at runtime **don’t** contain PAC/BTI instructions. This means JIT-compiled code doesn’t benefit from hardware-enforced return address signing or branch target restrictions.
To get full end-to-end PAC/BTI protection, including JIT-compiled Java code, you need a JVM that was built with branch protection enabled.
## What you’ve learned and what’s next
You’ve confirmed that the Google Cloud C4A platform exposes PAC and BTI at the hardware level, and that the OS and native libraries are already protected. The gap is in the JVM’s JIT compiler: the SUSE OpenJDK 17 package doesn’t generate PAC/BTI instructions in compiled Java code.
In the next section, you’ll install a JVM build that includes full PAC/BTI JIT support, closing this gap so that dynamically compiled Java code also benefits from hardware-enforced control-flow integrity.
