Simulate OpenBMC and UEFI pre-silicon on Neoverse RD-V3
What are OpenBMC and UEFI?
Set up the development environment for OpenBMC and UEFI
Run OpenBMC and host UEFI simulation on RD-V3 FVP
Monitor and control the host CPU using OpenBMC SOL and web UI
Customize IPMI commands in OpenBMC
Multiple UART consoles open in separate terminal windows for different subsystems, such as Neoverse V3, Cortex-M55, Cortex-M7, and the Cortex-A BMC. You should see boot logs for both the BMC and host UEFI across these consoles.
The consoles are graphical terminals and require a desktop session. If you’re connected over SSH only, the windows won’t render. To render the windows, launch the simulation from a desktop session.
Use the provided bridge:
socat -x tcp:localhost:5005 tcp:localhost:5067. Verify that these port mappings match the endpoints exposed by your running simulation.The host console should be accessible through SoL and display the host’s console output. You should see ongoing boot messages or a prompt from the host side.
Run
ipmitool raw 0x30 0x20 in the OpenBMC console. You’ll see hexadecimal bytes. Exclude the first byte, which represents the payload length, and decode the remaining bytes using the provided command. The decoded string should be Hello from OpenBMC IPMI!.
