OpenBMC provides Serial oOer LAN (SOL) so you can access the host console (RD-V3 FVP) remotely through the BMC without a physical serial cable. In this section, you create a virtual UART bridge with socat, verify the port mappings, and open the host console from the BMC web UI.
Run this command on the Linux machine where the simulation is running to bridge the BMC and host UART ports:
socat -x tcp:localhost:5005 tcp:localhost:5067
This command connects the host-side UART port 5005 to the BMC-side port 5067 to enable bidirectional serial communication.
If you see a Connection refused error, check the FVP logs to verify the port numbers:
fvp_boot.log, look for a line like:
terminal_ns_uart0: Listening for serial connection on port 5005obmc_boot.log, confirm the corresponding line:
terminal_3: Listening for serial connection on port 5067Ensure both ports are active and match the socat command arguments.
After the SOL bridge is established, run the following command from the OpenBMC console shell to simulate the host as powered on:
busctl set-property xyz.openbmc_project.State.Host /xyz/openbmc_project/state/host0 xyz.openbmc_project.State.Host CurrentHostState s xyz.openbmc_project.State.Host.HostState.Running
This command updates the BMC internal host state so UEFI can begin execution.
From your simulation host, launch a browser and open the BMC Web UI at:
https://127.0.0.1:4223
BMC web UI login
Login using the default credentials:
As a reminder, the first character of the password is the number 0, not a capital O.
From the Overview page, click the SOL Console button.
Web UI overview
The SOL terminal in the Web UI will display the host console output (UEFI shell or Linux login). You can type commands directly as if you were connected over a physical serial line.
Web UI SOL console
When you are connected to the SOL terminal, you can monitor the UEFI boot sequence, interact with the host shell, and run diagnostic or recovery workflows just as you would over a physical serial port.
This process confirms that OpenBMC manages host power and console access in your simulated environment.
In the next section, you extend this control by sending IPMI commands to the BMC to test low-level system interactions and implement custom OEM command handlers.
