This section explains the roles of OpenBMC and UEFI in the Arm server boot flow and why simulating their integration is essential for early-stage development.
OpenBMC
is a collaborative open-source firmware stack for Baseboard Management Controllers (BMC), hosted by the Linux Foundation.
BMCs are embedded controllers on server motherboards that enable both in-band and out-of-band system management. Out-of-band access allows remote management even when the host is powered off or unresponsive, while in-band interfaces support communication with the host operating system during normal operation.
The OpenBMC stack is built using the Yocto Project and includes a Linux kernel, system services, D-Bus interfaces, and support for industry-standard APIs such as Redfish and IPMI. It provides features like hardware monitoring, fan control, power sequencing, sensor telemetry, event logging, firmware/BIOS configuration, and more.
Its architecture is modular. Each board or platform can define its own layers and packages through Yocto recipes, enabling custom extensions without modifying upstream code.
OpenBMC is widely adopted by hyperscalers and enterprise vendors to manage servers, storage systems, and network appliances. It is particularly well-suited to Arm-based server platforms like Neoverse RD-V3 , where it provides early-stage platform control and boot orchestration even before silicon is available.
Key features of OpenBMC include:
OpenBMC enables faster development cycles, open innovation, and reduced vendor lock-in across data centers, cloud platforms, and edge environments.
In this Learning Path, you’ll simulate how OpenBMC manages the early-stage boot process, power sequencing, and remote access for a virtual Neoverse RD-V3 server. You will interact with the BMC console, inspect boot logs, and verify SOL and UART communication with the host.
The Unified Extensible Firmware Interface (UEFI) is the modern replacement for legacy BIOS, responsible for initializing hardware and loading the operating system. UEFI provides a robust, modular, and extensible interface between platform firmware and OS loaders. It supports:
UEFI executes after the platform powers on and before the OS kernel takes over. It discovers and initializes system hardware, configures memory and I/O, and launches the bootloader. It is governed by the UEFI Forum and is the standard firmware interface across server-class, desktop, and embedded systems.
In platforms that integrate OpenBMC, the BMC operates independently from the host CPU and manages platform power, telemetry, and recovery. During system boot, UEFI and OpenBMC coordinate via mechanisms such as IPMI over KCS, PLDM over MCTP, or shared memory buffers.
These interactions are especially critical in Arm server-class platforms—like Neoverse RD-V3—for secure boot, remote diagnostics, and system recovery during pre-silicon or bring-up phases.
| Interaction | Direction | Description |
| Boot power sequencing | BMC → Host | BMC controls host power-on flow, ensuring UEFI starts in the correct sequence |
| Boot status reporting | UEFI → BMC | UEFI reports boot state and progress via IPMI (KCS) or PLDM |
| Serial over LAN (SOL) | BMC ↔ Host | BMC bridges the host UART console to remote clients over the network |
| Pre-boot configuration | BMC ↔ UEFI | BMC may inject or read boot settings via shared memory or commands |
| System recovery signaling | UEFI → BMC | UEFI can request BMC-initiated reboot, NMI, or recovery actions |
In this Learning Path, you will build and run the UEFI firmware on the RD-V3 FVP host platform. You will use OpenBMC to power on the virtual Arm server, access the serial console, and monitor host boot progress like real hardware. By inspecting the full boot log and observing system behavior in simulation, you will see how BMC and UEFI coordinate during early firmware bring-up.
