There is more than one way to create an Arm-based Cobalt 100 virtual machine:
In this Learning Path, you will use the Azure portal to create a virtual machine with the Arm-based Azure Cobalt 100 processor.
You will focus on the general-purpose virtual machines in the D-series. For further information, see the Microsoft Azure guide for the Dpsv6 size series .
While the steps to create this instance are included here for convenience, for further information on setting up Cobalt on Azure, see Deploy a Cobalt 100 virtual machine on Azure Learning Path .
To launch an Arm-based virtual machine on Azure, you will use the Azure portal to create a Linux VM powered by the Cobalt 100 processor. This process is similar to creating any other Azure VM, but you will specifically select the Arm64 architecture and the D-Series v6 (D4ps_v6) size for optimal performance on Arm.
Follow these steps to deploy a Linux-based Azure Cobalt 100 VM:
Select the D-Series v6 family of virtual machines
Allow inbound port rules
Click on the Review + Create tab and review the configuration for your virtual machine. It should look like the following:
Review and Create an Azure Cobalt 100 Arm64 VM
When you are confident about your selection, click on the Create button, and click on the Download Private key and Create Resources button.
Your virtual machine should be ready and running within a few minutes. You can SSH into the virtual machine using the private key, along with the Public IP details.
You should see your Arm-based Azure Cobalt 100 VM listed as Running in the Azure portal. If you have trouble connecting, double-check your SSH key and ensure the correct ports are open. If the VM creation fails, check your Azure quota, region availability, or try a different VM size. For more troubleshooting tips, see the Deploy a Cobalt 100 virtual machine on Azure Learning Path .
Nice work! You have successfully provisioned an Arm-based Azure Cobalt 100 virtual machine. This setup is ideal for deploying Linux workloads, running ONNX Runtime, and benchmarking machine learning models on Arm64 infrastructure. You are now ready to continue with ONNX Runtime installation and performance testing in the next steps.
VM deployment confirmation in Azure portal
For further information or alternative setup options, see “Getting Started with Microsoft Azure” in Get started with Arm-based cloud instances .
