In this section, you will learn how to provision a Google Axion C4A Arm virtual machine on Google Cloud Platform (GCP) using the c4a-standard-4 (4 vCPUs, 16 GB memory) machine type in the Google Cloud Console.
For support on GCP setup, see the Learning Path Getting started with Google Cloud Platform .
To create a virtual machine based on the C4A instance type:
Navigate to the Google Cloud Console .
Go to Compute Engine > VM Instances and select Create Instance.
Under Machine configuration:
C4A.c4a-standard-4 for machine type.
Creating a Google Axion C4A Arm virtual machine in Google Cloud Console
Under OS and Storage, select Change, then choose an Arm64-based OS image. For this Learning Path, use SUSE Linux Enterprise Server or Ubuntu.
Once appropriately selected, please Click Select.
Under Networking, enable Allow HTTP traffic.
Click Create to launch the instance.
Once created, you should see a “SSH” option to the right in your list of VM instances. Click on this to launch a SSH shell into your VM instance:
Invoke a SSH session into your running VM instance
Terminal shell in your VM instance
Use the uname utility to verify that you are using an Arm-based server. For example:
uname -m
will identify the host machine as aarch64.
Install the gcc compiler:
sudo apt update
sudo apt install -y build-essential
sudo zypper refresh
sudo zypper install -y gcc
Using a text editor of your choice, create a file named hello.c with the contents below:
#include <stdio.h>
int main(){
printf("hello world\n");
return 0;
Build and run the application:
gcc hello.c -o hello
./hello
The output is shown below:
hello world
Cloud infrastructure deployment is typically done via Infrastructure as code (IaC) automation tools. There are Cloud Service Provider specific tools like Google Cloud Deployment Manager .
There are also Cloud Service Provider agnostic tools like Terraform .There is a deploying Arm VMs on (GCP) using Terraform learning path that should be reviewed next.
