Install Node Version Manager (NVM)
To install Node.js on your Arm-based VM, use Node Version Manager (NVM). NVM lets you select and manage different Node.js versions easily. By using official Node.js packages, you’ll get a reliable and straightforward setup.
First, use this command to download and install NVM into your VM instance:
curl -o- https://raw.githubusercontent.com/nvm-sh/nvm/v0.39.7/install.sh | bash
Next, activate Node Version Manager (NVM) in your current terminal session. Copy and paste the following commands into your shell to load NVM and enable command completion:
export NVM_DIR="$HOME/.nvm"
[ -s "$NVM_DIR/nvm.sh" ] && \. "$NVM_DIR/nvm.sh"
[ -s "$NVM_DIR/bash_completion" ] && \. "$NVM_DIR/bash_completion"
This step ensures that NVM commands are available in your shell. If you open a new terminal, repeat these commands or add them to your ~/.bashrc file for automatic activation:
[ -s "$NVM_DIR/nvm.sh" ] && \. "$NVM_DIR/nvm.sh"  # This loads nvm
[ -s "$NVM_DIR/bash_completion" ] && \. "$NVM_DIR/bash_completion"  # This loads nvm bash_completion
Confirm that NVM is available by typing:
nvm --version
Install Node.js
Now that NVM is installed, download and install Node.js:
nvm install v24
nvm use v24
Next, add this command to the bottom of your $HOME/.bashrc file:
echo 'nvm use v24' >> ~/.bashrc
Verify installation
Check that Node.js and npm (Node.js package manager) are installed correctly by using this command that confirms that NodeJS is installed and available:
node --version
npm --version
You should see an output similar to:
        v24.10.0
11.6.1
This shows you that Node.js installation is complete. You can now proceed with the baseline testing.
What you’ve accomplished
You’ve successfully provisioned a Google Axion C4A Arm virtual machine running SUSE Linux Enterprise Server. You’re now ready to install Node.js and deploy your workloads on Arm.
