Deploy Node.js on Google Cloud C4A Arm-based Axion virtual machines
Getting started with Node.js on Google Axion C4A (Arm Neoverse-V2)
Create a Google Axion C4A Arm virtual machine on GCP
Install Node.js using Node Version Manager
Validate Node.js baseline on Google Axion C4A Arm virtual machine
Benchmark Node.js performance with Autocannon
Use a C4A machine type, such as
c4a-standard-4 with four vCPUs and 16 GB. Select a SUSE Linux Enterprise Server image for Arm64.After installing Node.js with
nvm install v24, add nvm use v24 to your ~/.bashrc file. Place it after the commands that load NVM so that new Bash sessions select Node.js v24.Run the REPL test to print a message and start the sample HTTP server. Proceed when the server responds to an HTTP request on the configured port.
Use
http://localhost:80 when you run Autocannon on the same VM as the sample Node.js server.Adjust
-c to set the number of concurrent connections and -d to set the test duration in seconds. The example uses -c 100 -d 10 to run 100 concurrent connections for ten seconds.
