The profile of requests made by clients will differ based on the use case. This means there is no one size fits all set of tuning parameters for Nginx. Use the information below as general guidance to tune Nginx.
The Linux Network stack settings can be changed in the /etc/sysctl.conf file, or by using the sysctl command.
Documentation on each of the parameters discussed below can be found in the admin-guide and networking documentation within the Linux source.
Run the command below to list all kernel parameters.
sudo sysctl -a
Shown below are the network stack settings used for performance testing.
sudo sysctl -w net.core.somaxconn=65535
sudo sysctl -w net.core.rmem_max=8388607
sudo sysctl -w net.core.wmem_max=8388607
sudo sysctl -w net.ipv4.tcp_max_syn_backlog=65535
sudo sysctl -w net.ipv4.ip_local_port_range="1024 65535"
sudo sysctl -w net.ipv4.tcp_rmem="4096 8338607 8338607"
sudo sysctl -w net.ipv4.tcp_wmem="4096 8338607 8338607"
These settings open up the network stack to make sure it is not a bottleneck.
net.core.somaxconn:net.core.rmem_max:ss (Socket Statistics). The information provided by this tool can be used to select a value for this parameter.net.core.wmem_max:ss (Socket Statistics). The information provided by this tool can be used to select a value for this parameter.net.ipv4.tcp_max_syn_backlog:net.ipv4.ip_local_port_range:net.ipv4.tcp_rmem:ss (Socket Statistics). The information provided by this tool can be used to select a value for this parameter.net.ipv4.tcp_wmem:ss (Socket Statistics). The information provided by this tool can be used to select a value for this parameter.The easiest way to gain performance is to use the latest version of GCC. Aside from that, the flag -mcpu can be used to potentially gain additional performance. Usage of this flag is explained in the
Migrating C/C++ applications
section of the
Migrating applications to Arm servers
learning path.
If you need to understand how to configure a build of Nginx. Please review the build Nginx from source section of the Learn to deploy Nginx learning path .
Nginx relies on OpenSSL for cryptographic operations. Thus, the version of OpenSSL used with Nginx (and the GCC version and switches used to compile it) can impact performance. Typically using the Linux distribution default version of OpenSSL is sufficient.
However, it is possible to use newer versions of OpenSSL which could yield performance improvements. This is achieved by using the --with-openssl switch when configuring the Nginx build. Point this switch to the directory that contains the source code of the version of OpenSSL you’d like to have Nginx link to. The Nginx build system takes care of the rest. There is also a --with-openssl-opt switch which allows you to add options to the build for OpenSSL.
The version of OpenSSL Nginx is using can be verified by running the command nginx -V.
Nginx relies on PCRE for regular expression processing. One scenario where regular expressions are used is for an API Gateway. Typically, using the Linux distribution default version of PCRE is sufficient. However, it is possible to use a newer version of PCRE to potentially gain performance. The Nginx installation instructions explain how to build the latest version of PCRE if this is something you want to explore.
Nginx relies on
zlib
for HTTP response compression (when the ngx_http_gzip_module directives are used). Typically, using the Linux distribution default version of zlib is sufficient. However, it is possible to use a newer version of zlib to potentially gain performance. The Nginx
explain how to build the latest version of zlib if this is something you want to explore.
