Deploy NGINX on Azure Cobalt 200 Arm-based virtual machines
Overview of Azure Cobalt 200 and NGINX
Create an Arm-based Azure VM with Cobalt 200
Install NGINX
NGINX Baseline Testing
NGINX Benchmarking
Use an Arm-based VM in the Dpsv7 series with the Ubuntu 24.04 LTS Arm64 image.
Run
sudo systemctl status nginx and check for Active: active (running). Use curl -I http://localhost/ to check for HTTP/1.1 200 OK. Then, open your VM’s public IP address in a browser to confirm that you see the default welcome page.Create
/var/www/my-static-site/index.html and configure /etc/nginx/conf.d/static-site.conf to use that directory and index.html. Remove the packaged default site if present with sudo rm -f /etc/nginx/sites-enabled/default. Run sudo nginx -t before sudo nginx -s reload, then open your VM’s public IP address to check your custom page.Run ApacheBench on your NGINX VM to match the demonstrated baseline test. Use
ab -n 1000 -c 50 http://localhost/ to send 1,000 requests with 50 concurrent connections.Install the
apache2-utils package. Run ab -V to confirm that ApacheBench is available and prints a version string.
