# Next Steps
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/net-aspire/)
- [.NET Aspire](https://learn.arm.com/learning-paths/servers-and-cloud-computing/net-aspire/background/)
- [Create a project and then an application](https://learn.arm.com/learning-paths/servers-and-cloud-computing/net-aspire/project/)
- [Run the application](https://learn.arm.com/learning-paths/servers-and-cloud-computing/net-aspire/run_app/)
- [Modify the Project](https://learn.arm.com/learning-paths/servers-and-cloud-computing/net-aspire/modify_project/)
- [Deploy to AWS EC2](https://learn.arm.com/learning-paths/servers-and-cloud-computing/net-aspire/aws/)
- [Deploy to GCP](https://learn.arm.com/learning-paths/servers-and-cloud-computing/net-aspire/gcp/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/net-aspire/_next-steps/)
## Explore related resources
- [.NET Aspire Overview](https://learn.microsoft.com/en-us/dotnet/aspire/get-started/aspire-overview)
- [Compute Service - Amazon EC2](https://aws.amazon.com/pm/ec2)
- [Compute Service - Google GCP](https://cloud.google.com/products/compute/)
## Review frequently asked questions
### How do I verify the .NET SDK and install the Aspire workload before creating the project?
Run `dotnet --version` in PowerShell and confirm that you have .NET SDK 8.0 or later. Then run `dotnet workload install aspire` and check for `Successfully installed workload(s) aspire.`
### Why do I need to trust the HTTPS development certificate, and how do I do it?
You use HTTPS when running the application locally. Run `dotnet dev-certs https --trust` before starting your application to trust its HTTPS development certificate.
### Which project do I run to start the distributed application, and what output should I expect?
From the project directory, run `dotnet run --project NetAspire.Arm.AppHost`. You should see messages such as `Building...`, an Aspire version line, and `Distributed application starting`.
### Where do I add the intensive computations, and how can I confirm the change worked?
Add the supplied `ComputationService.cs` code to `NetAspire.Arm.ApiService`. In `Program.cs`, update the `/weatherforecast` handler to call `ComputationService.PerformIntensiveCalculations(matrixSize: 800)`. Run `dotnet run --project NetAspire.Arm.AppHost`, select **Weather** in your web frontend, then open **Traces** in the dashboard to inspect the longer request duration.
### Which ports do I need to expose to access the deployed application?
Allow TCP traffic on the ports that your application uses. The example uses `7133`, `7511`, and `17222`. Match your application’s port values in the Amazon EC2 security group or a Google Cloud firewall rule associated with your VM’s `dotnet-app` network tag.
