How the virtualization layers are pinned
To measure the overhead of nested virtualization, you’ll install and run a reference benchmark across the three layers: L0 (bare metal), the L1 guest VM, and the L2 guest VM. To make the test comparable and minimize interaction with other workloads running on the server, pin each system under test to a fixed set of host cores.
The following table shows how each system is pinned:
System under testvCPUsPinned to
Host (L0) benchmarkN/AHost cores 8-15
L1 guest0-7Host cores 16-23
L1 hypervisor0-15Host cores 24-39
L2 guest0-7Hypervisor cores 8-15 (host cores 32-39)
After the core pinning is in place and sysbench is installed on all systems under test, run the test. Verify that the correct cores run at 100% CPU for the duration of the test. Check the results to see how much virtualization passthrough affects performance. Apply this core pinning while the VMs are running by using the --live flag for virsh.
Pin cores for the L1 guest and L1 hypervisor
Pin the cores for the L1 guest and L1 hypervisor:
 # Pin L1 guest to cores 16-23
 for i in $(seq 0 7); do
   sudo virsh vcpupin fedora-l1-guest $i $((i+16)) --config --live
 done
 sudo virsh emulatorpin fedora-l1-guest 16-23 --config --live
 # Pin L1 hypervisor to cores 24-39
 for i in $(seq 0 15); do
   sudo virsh vcpupin fedora-l1-hyper $i $((i+24)) --config --live
 done
 sudo virsh emulatorpin fedora-l1-hyper 24-39 --config --live
Pin cores for the L2 guest
Log in to fedora-l1-hyper and pin the cores of fedora-l2-guest to cores 8-15:
 # On host:
 ssh -i ~/.ssh/guest_key fedora@${fedora-l1-hyper IP address}
 # Inside L1 hypervisor: pin L2 guest to vCPUs 8-15
   sudo virsh vcpupin fedora-l2-guest $i $((i+8)) --config --live
 done
 sudo virsh emulatorpin fedora-l2-guest 8-15 --config --live
Verify the core pinning
Verify that the pinning is correct, replacing <domain> with the domain name for each of the VMs, such as fedora-l1-guest:
sudo virsh vcpuinfo <domain>
sudo virsh emulatorpin <domain>
Install sysbench
Install the sysbench benchmarking tool on the host, the L1 guest VM, and the L2 guest VM:
sudo dnf install -y sysbench
Run the benchmark
Run the same benchmark test on each system under test. You can run the tests in three different terminals at the same time. The tests shouldn’t significantly interfere with each other because they use different cores.
On the bare metal host, use taskset to bind the benchmark to physical cores 8 to 15:
taskset -c 8-15 sysbench cpu --cpu-max-prime=20000 --threads=8 --time=60 run
On the L1 guest and the L2 guest VMs, run the benchmark without taskset, because you already pinned their virtual CPUs with virsh:
For one run, the output is similar to:
        sysbench 1.0.20 (using system LuaJIT 2.1.1761727121)
Running the test with following options:
Number of threads: 8
Initializing random number generator from current time
Prime numbers limit: 20000
Initializing worker threads...
Threads started!
CPU speed:
    events per second:  9693.21
General statistics:
    total time:                          60.0007s
    total number of events:              581607
Latency (ms):
         min:                                    0.82
         avg:                                    0.83
         max:                                    0.98
         95th percentile:                        0.83
         sum:                               479906.25
Threads fairness:
    events (avg/stddev):           72700.8750/20.69
    execution time (avg/stddev):   59.9883/0.00
How to read the output
The following fields matter most for comparing the three layers:
  • events per second under CPU speed is the throughput. Higher is better. This is the primary number to compare across bare metal, L1, and L2.
  • The Latency (ms) block reports per-request latency. min, avg, and 95th percentile describe typical responsiveness, while max captures the worst-case spike. Lower is better.
  • events (avg/stddev) under Threads fairness shows how evenly work was spread across threads. The second number is the standard deviation. A smaller value means more even distribution.
Record your results
Run the benchmark on each layer and record the values from your own output.
To calculate the overhead for a layer, compare its events per second against the bare metal result:
overhead = (bare_metal_events_per_second - layer_events_per_second) / bare_metal_events_per_second * 100
For example, if bare metal reports 9693 events per second and the L2 nested guest reports 9219 events per second, the overhead is (9693 - 9219) / 9693 * 100, or less than 5%.
Compare the events per second and latency values across the three layers to see how virtualization and nested virtualization affect your workload. The average and 95th percentile latencies are often close across all three layers. The maximum latency tends to increase with each level of nesting.
Note
Results vary with the Arm server, CPU generation, kernel, and workload. Draw conclusions from your own measurements rather than from any single reference figure. Nested virtualization support continues to improve, so newer Arm Neoverse generations typically show lower overhead than older ones. Focus on the relative difference between bare metal, L1, and L2 on your own hardware.
The following is an example set of results:
MetricBare MetalL1 KVM GuestL2 Nested Guest
Events per second2533.022525.842306.22
Overhead versus bare metalN/A-0.3%-8.9%
Min latency3.14ms3.15ms3.38ms
Avg latency3.16ms3.17ms3.47ms
Max latency9.16ms13.02ms19.72ms
95th percentile3.13ms3.19ms3.55ms
Thread stddev52.1841.4673.47
What you’ve accomplished
You’ve pinned CPU cores across all three layers and benchmarked them with sysbench.
You can now use the techniques described in the Learning Path to run VMs inside VMs on Arm for workload isolation, hypervisor development and testing, or running microVMs in cloud environments.
