Configure and run nested virtualization on an Arm server
Prepare the host for nested virtualization
Prepare and start an L1 guest virtual machine
Create a hypervisor virtual machine on the host
Prepare and boot a nested L2 guest VM in the hypervisor VM
Benchmark Arm nested virtualization with sysbench
Repeat VM setup in the hypervisor VM
You’ll copy the base image and private SSH key from the host to the fedora-l1-hyper VM, then install the virtualization tools there. After that, you’ll resize the L2 guest disk, create a new seed ISO, and re-run virt-install for fedora-l2-guest.
Copy the image and SSH key to the hypervisor
Copy the Fedora cloud image and private SSH key from the host into the hypervisor using scp:
# In the host:
scp -i ~/.ssh/guest_key $IMG ~/.ssh/guest_key fedora@{fedora-l1-hyper IP address}:~/
Install the virtualization stack in the hypervisor
Log in to the fedora-l1-hyper VM, and install the same virtualization software stack that you installed on the host:
sudo dnf -y install libvirt libvirt-daemon-qemu libvirt-client qemu-kvm virt-install dnsmasq genisoimage
Restart the hypervisor VM
After the installation completes, restart the hypervisor VM from the host to start virtualization services:
# In the host:
sudo virsh reboot fedora-l1-hyper
# After boot is complete
ssh -i ~/.ssh/guest_key fedora@{fedora-l1-hyper IP address}
Wait for about a minute to connect again with SSH.
Create the L2 guest image
After the VM restarts, connect to it again and create the L2 guest VM image:
export VMDIR="/var/lib/libvirt/images"
export IMG="/home/fedora/Fedora-Cloud-Base-Generic-44-1.7.aarch64.qcow2"
export DISK_L2_GUEST="/var/lib/libvirt/images/fedora-l2-guest.qcow2"
# Prepare the L2 guest image
sudo cp "$IMG" "$DISK_L2_GUEST"
sudo qemu-img resize "$DISK_L2_GUEST" 40G
Create a cloud-init seed ISO
Create a seed ISO image for cloud-config similar to the other VMs.
You copied the private key (~/guest_key) into the hypervisor earlier. Derive the matching public key from it to use in ssh_authorized_keys:
ssh-keygen -y -f ~/guest_key
Use the output of that command in place of <your-public-key>:
cat > /tmp/user-data <<EOF
#cloud-config
users:
- name: fedora
sudo: ALL=(ALL) NOPASSWD:ALL
shell: /bin/bash
- <your-public-key>
chpasswd:
expire: False
ssh_pwauth: False
EOF
cat > /tmp/meta-data <<EOF
instance-id: my-l2-guest
local-hostname: my-l2-guest
EOF
SEEDTMP=$(mktemp -d)
cp /tmp/user-data "$SEEDTMP/user-data"
cp /tmp/meta-data "$SEEDTMP/meta-data"
genisoimage -output ${HOME}/seed_guest.iso \
-volid cidata -joliet -rock -input-charset utf-8 \
"$SEEDTMP/user-data" "$SEEDTMP/meta-data"
sudo cp ${HOME}/seed_guest.iso ${VMDIR}
rm -rf "$SEEDTMP"
Start the L2 guest VM
Start the L2 guest VM using virt-install:
sudo virt-install \
--name fedora-l2-guest \
--memory 8192 \
--vcpus 8 \
--arch aarch64 \
--machine virt \
--disk path=${DISK_L2_GUEST},format=qcow2,bus=virtio \
--disk path=${VMDIR}/seed_guest.iso,device=cdrom,readonly=on \
--network network=default,model=virtio \
--os-variant fedora43 \
--import \
--noautoconsole
Connect to the L2 guest over SSH
After the VM starts, find its IP address and connect to it with SSH:
sudo virsh net-dhcp-leases default
ssh -i ~/guest_key fedora@{fedora-l2-guest ip address}
You’ve now connected to an L2 guest VM over SSH. The L2 guest VM is running inside an L1 hypervisor VM.
Next, you’ll use a synthetic benchmark, sysbench, to measure the overhead of running an application inside a nested VM.
