Configure and run nested virtualization on an Arm server
Prepare the host for nested virtualization
Prepare and start an L1 guest virtual machine
Create a hypervisor virtual machine on the host
Prepare and boot a nested L2 guest VM in the hypervisor VM
Benchmark Arm nested virtualization with sysbench
Why create a guest VM
Before creating a nested virtual machine (VM), create an L1 guest VM running on the host. The guest VM gives you an unnested VM to compare the performance overhead of virtualization against the additional overhead of nested virtualization.
To create a guest VM, download a cloud image. Make some configuration changes to the base image using cloud-config. Then, install and start the VM using virt-install. After the VM starts, connect to it to confirm that it started correctly.
Download an Arm64 cloud image
Download an Arm64 cloud image to use for the VMs:
curl -LO https://dl.fedoraproject.org/pub/fedora/linux/releases/44/Cloud/aarch64/images/Fedora-Cloud-Base-Generic-44-1.7.aarch64.qcow2
To be consistent with the host, Fedora 44 is used in this example. Any recent Linux distribution works.
Copy and resize the disk image
Make a copy of the base disk image and resize it to give the VM more disk space. For convenience, also set some environment variables:
export VMDIR="/var/lib/libvirt/images"
export IMG="${HOME}/Fedora-Cloud-Base-Generic-44-1.7.aarch64.qcow2"
export DISK_L1_GUEST="${VMDIR}/fedora-l1-guest.qcow2"
# Prepare the L1 guest image
sudo cp "$IMG" "$DISK_L1_GUEST"
sudo qemu-img resize "$DISK_L1_GUEST" 40G
Create a cloud-init seed ISO
Create a seed ISO image for cloud-init. cloud-init runs automatically the first time you instantiate the VM, and it can perform some initialization actions for you. cloud-init looks for special files called meta-data and user-data for configuration information.
You’ll create a default unprivileged user (fedora) and ensure that the user has permission to run commands as root using sudo without a password. You’ll include your public SSH key in the authorized_keys of that user so that you can SSH into the VM from the host.
If you don’t already have an SSH key-pair to use for the guest VMs, generate a key-pair on the host:
ssh-keygen -t ed25519 -f ~/.ssh/guest_key -N ""
This creates a private key at ~/.ssh/guest_key and a public key at ~/.ssh/guest_key.pub.
Create the user-data and meta-data files, then generate the seed ISO image that you’ll attach to the VM. In the user-data file, replace <your-public-key> with the contents of ~/.ssh/guest_key.pub. You’ll use the matching private key, ~/.ssh/guest_key, to connect to the VM later. Copy the ISO to the same directory as the qcow2 VM image that you created earlier:
cat > /tmp/user-data <<EOF
#cloud-config
users:
- name: fedora
sudo: ALL=(ALL) NOPASSWD:ALL
shell: /bin/bash
ssh_authorized_keys:
- <your-public-key>
chpasswd:
expire: False
ssh_pwauth: False
EOF
cat > /tmp/meta-data <<EOF
instance-id: my-guest
local-hostname: my-guest
EOF
SEEDTMP=$(mktemp -d)
cp /tmp/user-data "$SEEDTMP/user-data"
cp /tmp/meta-data "$SEEDTMP/meta-data"
genisoimage -output ${HOME}/seed_guest.iso \
-volid cidata -joliet -rock -input-charset utf-8 \
"$SEEDTMP/user-data" "$SEEDTMP/meta-data"
sudo cp ${HOME}/seed_guest.iso ${VMDIR}
rm -rf "$SEEDTMP"
Start the L1 guest VM
Start the L1 guest VM using virt-install:
sudo virt-install \
--name fedora-l1-guest \
--memory 8192 \
--vcpus 8 \
--arch aarch64 \
--machine virt \
--disk path=${DISK_L1_GUEST},format=qcow2,bus=virtio \
--disk path=${VMDIR}/seed_guest.iso,device=cdrom,readonly=on \
--network network=default,model=virtio \
--os-variant fedora43 \
--import \
--noautoconsole
The virt-install command includes parameters for the following:
- The VM image
- The ISO CD image that you created for
cloud-config - A
nameto identify the image withvirshandvirt-manager - The number of virtual CPUs and amount of memory allocated to the VM
The os-variant argument passes hints about which operating system runs. At the time of writing, fedora44 isn’t yet an accepted os-variant value. fedora43, the most recent value that the osinfo database recognizes, is used in the command as an example.
Connect to the guest VM over SSH
After the VM starts, find its IP address with virsh net-dhcp-leases:
sudo virsh net-dhcp-leases default
The output is similar to:
Expiry Time MAC address Protocol IP address Hostname Client ID or DUID
2026-10-06 17:11:32 52:54:00:ca:0a:64 ipv4 192.168.122.171/24 - -
Use the IP address from the output to connect with the private key that you created earlier:
ssh -i ~/.ssh/guest_key fedora@192.168.122.171
The DHCP lease can appear before the VM finishes its first boot. If SSH reports Connection refused, wait for cloud-init to finish and the SSH service to start, then try again.
You’ve now created an L1 guest VM and connected to it over SSH. After you’ve verified that you can connect to the L1 guest VM, exit the shell to return to the host environment.
Next, you’ll instantiate a hypervisor VM.
