# Next Steps
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/neoverse-rdv3-swstack/)
- [Learn about the Arm RD-V3 Platform](https://learn.arm.com/learning-paths/servers-and-cloud-computing/neoverse-rdv3-swstack/1_introduction_rdv3/)
- [Understand the CSS-V3 boot flow and firmware stack](https://learn.arm.com/learning-paths/servers-and-cloud-computing/neoverse-rdv3-swstack/2_rdv3_bootseq/)
- [Build the RD-V3 Reference Platform Software Stack](https://learn.arm.com/learning-paths/servers-and-cloud-computing/neoverse-rdv3-swstack/3_rdv3_sw_build/)
- [Simulate RD-V3 Boot Flow on Arm FVP](https://learn.arm.com/learning-paths/servers-and-cloud-computing/neoverse-rdv3-swstack/4_rdv3_on_fvp/)
- [Simulate Dual Chip RD-V3-R1 Platform](https://learn.arm.com/learning-paths/servers-and-cloud-computing/neoverse-rdv3-swstack/5_rdv3_modify/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/neoverse-rdv3-swstack/_next-steps/)
## Explore related resources
- [Neoverse Compute Subsystems V3](https://www.arm.com/products/neoverse-compute-subsystems/css-v3)
- [Reference Design software stack architecture](https://neoverse-reference-design.docs.arm.com/en/latest/about/software_stack.html)
- [GitLab infra-refdesign-manifests](https://git.gitlab.arm.com/infra-solutions/reference-design/infra-refdesign-manifests)
## Review frequently asked questions
### How do I choose the correct FVP model for my RD-V3 build?
Match your FVP version to your RD-V3 release tag. For `RD-INFRA-2025.07.03`, use FVP version `11.29.35`. Check the release tags list for other version mappings.
### What result should I expect when the single-die simulation boots successfully?
In `terminal_ns_uart0`, select **RD-V3 Buildroot** from the GRUB menu and press **Enter**. You should see `Welcome to Buildroot`, then a `buildroot login:` prompt. Log in as `root` to reach the Linux shell.
### Where can I find the UART logs from the RD-V3 simulation?
Look in `~/rdv3/model-scripts/rdinfra/platforms/rdv3/rdv3`, where each UART is redirected to its own log file. Use the UART-to-terminal mapping to identify the subsystem you want to inspect, such as Linux, TF-A and UEFI, SCP, RSE, MCP, or LCP.
### How do I validate the MCP firmware change on RD-V3-R1?
Add `FWK_LOG_CRIT("[FWK] Customer code here");` in `fwk_module_start()` in `~/rdv3r1/host/scp/framework/src/fwk_module.c`. Rebuild and repackage with `rdv3r1` build commands, then relaunch the FVP. Check your MCP UART output for `[FWK] Customer code here` to confirm that your change executes.
### How do I know the dual-chip RD-V3-R1 simulation is running correctly?
After launching `./boot-buildroot.sh -p rdv3r1`, check the UART consoles to verify that both application processors, AP0 and AP1, boot in coordination. You can inspect the additional MCP console and logs in `~/rdv3r1/model-scripts/rdinfra/platforms/rdv3r1/rdv3r1`.
