In this module, you’ll set up your development environment on any Arm-based server and build the firmware stack required to simulate the RD-V3 platform. This Learning Path was tested on an AWS m7g.4xlarge Arm-based instance running Ubuntu 22.04.
First, check that your system is current and install the required dependencies:
sudo apt update
sudo apt install -y curl git
Configure git(optional):
git config --global user.name "<your-name>"
git config --global user.email "<your-email@example.com>"
The RD‑V3 platform firmware stack consists of multiple components, most maintained in separate Git repositories, such as:
Use the repo tool with the RD-V3 manifest to sync these sources from multiple upstreams consistently (typically to a pinned release tag). It simplifies syncing the full platform software stack from multiple upstreams.
If repo is not installed, you can download it and add it to your PATH:
mkdir -p ~/.bin
PATH="${HOME}/.bin:${PATH}"
curl https://storage.googleapis.com/git-repo-downloads/repo > ~/.bin/repo
chmod a+rx ~/.bin/repo
Once ready, create a workspace and initialize the repo manifest. This Learning Path uses a pinned manifest to ensure reproducibility across different environments. This locks all component repositories to known-good commits that are validated and aligned with a specific FVP version.
For this session, use pinned-rdv3.xml and RD-INFRA-2025.07.03:
cd ~
mkdir rdv3
cd rdv3
Initialize and sync the source code tree:
repo init -u https://git.gitlab.arm.com/infra-solutions/reference-design/infra-refdesign-manifests.git -m pinned-rdv3.xml -b refs/tags/RD-INFRA-2025.07.03 --depth=1
repo sync -c -j $(nproc) --fetch-submodules --force-sync --no-clone-bundle --retry-fetches=5
Once synced, the output should look like:
Syncing: 95% (19/20), done in 2m36.453s
Syncing: 100% (83/83) 2:52 | 1 job | 0:01 platsw/edk2-platforms @ uefi/edk2/edk2-platformsrepo sync has finished successfully.
As of the time of writing, the latest release tag is RD-INFRA-2025.07.03. Newer tags might be available in future updates.
This manifest fetches the required sources, including:
There are two supported methods for building the reference firmware stack: host-based and container-based.
In this Learning Path, you will use the container-based approach.
The container image uses your host source directory (~/rdv3) and performs the build inside Docker. Ensure Docker is installed on your machine. You can follow this installation guide .
After Docker is installed, you’re ready to build the container image.
The container.sh script is a wrapper that builds the container using default settings for the Dockerfile and image name. You can customize these by using the -f (Dockerfile) and -i (image name) options, or by editing the script directly.
To view all available options:
cd ~/rdv3/container-scripts
./container.sh -h
To build the container image:
./container.sh build
The build procedure can take a few minutes, depending on network bandwidth and CPU performance. This Learning Path was tested on an AWS m7g.4xlarge instance, and the build took 250 seconds.
Expected output:
Building docker image: rdinfra-builder ...
[+] Building 239.7s (19/19) FINISHED docker:default
=> [internal] load build definition from rd-infra-arm64 0.0s
=> => transferring dockerfile: 4.50kB 0.0s
=> [internal] load metadata for docker.io/library/ubuntu:jammy-20240911.1 1.0s
=> [internal] load .dockerignore 0.0s
=> => transferring context: 2B 0.0s
=> [internal] load build context 0.0s
=> => transferring context: 10.80kB 0.0s
=> [ 1/14] FROM docker.io/library/ubuntu:jammy-20240911.1@sha256:0e5e4a57c2499249aafc3b40fcd541e9a456aab7296681a3994d631587203f97 1.7s
=> => resolve docker.io/library/ubuntu:jammy-20240911.1@sha256:0e5e4a57c2499249aafc3b40fcd541e9a456aab7296681a3994d631587203f97 0.0s
=> => sha256:0e5e4a57c2499249aafc3b40fcd541e9a456aab7296681a3994d631587203f97 6.69kB / 6.69kB 0.0s
=> => sha256:7c75ab2b0567edbb9d4834a2c51e462ebd709740d1f2c40bcd23c56e974fe2a8 424B / 424B 0.0s
=> => sha256:981912c48e9a89e903c89b228be977e23eeba83d42e2c8e0593a781a2b251cba 2.31kB / 2.31kB 0.0s
=> => sha256:a186900671ab62e1dea364788f4e84c156e1825939914cfb5a6770be2b58b4da 27.36MB / 27.36MB 1.1s
=> => extracting sha256:a186900671ab62e1dea364788f4e84c156e1825939914cfb5a6770be2b58b4da 0.5s
=> [ 2/14] RUN apt-get update -q=2 && apt-get install -q=2 --yes --no-install-recommends ca-certificates curl 12.5s
=> [ 3/14] RUN wget -O - https://apt.kitware.com/keys/kitware-archive-latest.asc 2>/dev/null | gpg --dearmor - | tee /etc/apt/trust 0.5s
=> [ 4/14] RUN apt-get update -q=2 && apt-get install -q=2 --yes --no-install-recommends acpica-tools autoconf 40.0s
=> [ 5/14] RUN pip3 install --no-cache-dir poetry 7.4s
=> [ 6/14] RUN curl https://storage.googleapis.com/git-repo-downloads/repo > /usr/bin/repo && chmod a+x /usr/bin/repo 0.3s
=> [ 7/14] COPY common/install-openssl.sh /tmp/common/ 0.0s
=> [ 8/14] RUN bash /tmp/common/install-openssl.sh /opt 32.7s
=> [ 9/14] COPY common/install-gcc.sh /tmp/common/ 0.0s
=> [10/14] COPY common/install-clang.sh /tmp/common/ 0.0s
=> [11/14] RUN bash /tmp/common/install-gcc.sh /opt 13.2.rel1 "arm-none-eabi" 19.8s
=> [12/14] RUN bash /tmp/common/install-gcc.sh /opt 13.2.rel1 "aarch64-none-elf" 13.4s
=> [13/14] RUN bash /tmp/common/install-clang.sh /opt 15.0.6 101.2s
=> [14/14] COPY common/entry.sh /root/entry.sh 0.0s
=> exporting to image 9.2s
=> => exporting layers 9.2s
=> => writing image sha256:3a395c5a0b60248881f9ad06048b97ae3ed4d937ffb0c288ea90097b2319f2b8 0.0s
=> => naming to docker.io/library/rdinfra-builder 0.0s
Verify the image:
docker images
You should see a docker image called rdinfra-builder:
REPOSITORY TAG IMAGE ID CREATED SIZE
rdinfra-builder latest 3a395c5a0b60 4 minutes ago 8.12GB
Quick interactive test:
./container.sh -v ~/rdv3 run
This script mounts your source directory (~/rdv3) into the container and opens a shell session at that location. Inside the container, you should see a prompt like this:
Running docker image: rdinfra-builder ...
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
your-username:hostname:/home/your-username/rdv3$
You can explore the container environment if you wish, then type exit to return to the host.
Building the full firmware stack involves compiling several components and packaging them for simulation. The following command runs build and then package inside the Docker image:
Ensure you’re back in the host OS, then run:
cd ~/rdv3
docker run --rm \
-v "$PWD:$PWD" \
-w "$PWD" \
--mount type=volume,dst="$HOME" \
--env ARCADE_USER="$(id -un)" \
--env ARCADE_UID="$(id -u)" \
--env ARCADE_GID="$(id -g)" \
-t -i rdinfra-builder \
bash -c "./build-scripts/rdinfra/build-test-buildroot.sh -p rdv3 build && \
./build-scripts/rdinfra/build-test-buildroot.sh -p rdv3 package"
The build artifacts will be placed under ~/rdv3/output/rdv3/rdv3/, where the last rdv3 in the directory path corresponds to the selected platform name.
Inspect the artifacts:
ls ~/rdv3/output/rdv3/rdv3 -al
Expected output:
total 7092
drwxr-xr-x 2 ubuntu ubuntu 4096 Aug 12 13:15 .
drwxr-xr-x 4 ubuntu ubuntu 4096 Aug 12 13:15 ..
lrwxrwxrwx 1 ubuntu ubuntu 25 Aug 12 13:15 Image -> ../components/linux/Image
lrwxrwxrwx 1 ubuntu ubuntu 35 Aug 12 13:15 Image.defconfig -> ../components/linux/Image.defconfig
-rw-r--r-- 1 ubuntu ubuntu 7250838 Aug 12 13:15 fip-uefi.bin
lrwxrwxrwx 1 ubuntu ubuntu 32 Aug 12 13:15 lcp_ramfw.bin -> ../components/rdv3/lcp_ramfw.bin
lrwxrwxrwx 1 ubuntu ubuntu 26 Aug 12 13:15 lkvm -> ../components/kvmtool/lkvm
lrwxrwxrwx 1 ubuntu ubuntu 32 Aug 12 13:15 mcp_ramfw.bin -> ../components/rdv3/mcp_ramfw.bin
lrwxrwxrwx 1 ubuntu ubuntu 26 Aug 12 13:15 rmm.img -> ../components/rdv3/rmm.img
lrwxrwxrwx 1 ubuntu ubuntu 32 Aug 12 13:15 scp_ramfw.bin -> ../components/rdv3/scp_ramfw.bin
lrwxrwxrwx 1 ubuntu ubuntu 29 Aug 12 13:15 tf-bl1.bin -> ../components/rdv3/tf-bl1.bin
lrwxrwxrwx 1 ubuntu ubuntu 29 Aug 12 13:15 tf-bl2.bin -> ../components/rdv3/tf-bl2.bin
lrwxrwxrwx 1 ubuntu ubuntu 30 Aug 12 13:15 tf-bl31.bin -> ../components/rdv3/tf-bl31.bin
lrwxrwxrwx 1 ubuntu ubuntu 53 Aug 12 13:15 tf_m_flash.bin -> ../components/arm/rse/neoverse_rd/rdv3/tf_m_flash.bin
lrwxrwxrwx 1 ubuntu ubuntu 46 Aug 12 13:15 tf_m_rom.bin -> ../components/arm/rse/neoverse_rd/rdv3/rom.bin
lrwxrwxrwx 1 ubuntu ubuntu 48 Aug 12 13:15 tf_m_vm0_0.bin -> ../components/arm/rse/neoverse_rd/rdv3/vm0_0.bin
lrwxrwxrwx 1 ubuntu ubuntu 48 Aug 12 13:15 tf_m_vm1_0.bin -> ../components/arm/rse/neoverse_rd/rdv3/vm1_0.bin
lrwxrwxrwx 1 ubuntu ubuntu 33 Aug 12 13:15 uefi.bin -> ../components/css-common/uefi.bin
Reference mapping:
| Component | Output Files | Description |
| TF‑A | bl1.bin, bl2.bin, bl31.bin, fip.bin | Entry-level boot firmware |
| SCP and RSE firmware | scp.bin, mcp_rom.bin, etc. | Platform power/control |
| UEFI | uefi.bin, flash0.img | Boot device enumeration |
| Linux kernel | Image | OS payload |
| Initrd | rootfs.cpio.gz | Minimal filesystem |
You can also build from within an interactive container session (useful for debugging or partial builds):
Start your docker container. In your running container shell:
cd ~/rdv3
You’ve now prepared and built the full RD-V3 firmware stack. In the next section, you’ll install the appropriate FVP and simulate the full boot sequence, bringing the firmware to life on a virtual platform.
