To ensure the platform transitions securely and reliably from power-on to operating system launch, this section introduces the roles and interactions of each firmware component within the RD-V3 boot process. You’ll learn how each component contributes to system initialization and how control is systematically handed off across the boot chain.
In the RD-V3 platform, each firmware component such as TF-A, RSE, SCP, MCP, LCP, and UEFI operates independently but participates in a well-defined sequence. Each is delivered as a separate firmware image, yet they coordinate tightly through a structured boot flow and inter-processor signaling.
The following diagram from the Neoverse Reference Design documentation illustrates the progression of component activation from initial reset to OS handoff:
Boot Flow for RD-V3 Single Chip
After BL2, the Runtime Security Engine (RSE, Cortex-M55) authenticates critical firmware components that include SCP, UEFI, and kernel images, using secure-boot mechanisms. It performs cryptographic measurements and establishes a Root of Trust (RoT) before allowing other processors to start.
RSE acts as the platform’s security gatekeeper.
Once RSE completes verification, the System Control Processor (SCP, Cortex-M7) and the Management Control Processor (MCP, where present) are released from reset.
They perform essential bring-up:
SCP/MCP are the ground crew bringing hardware systems online.
When the AP is released, it begins executing Trusted Firmware-A (TF-A) at EL3 from the reset vector address programmed during boot-image layout. TF-A configures the secure world, sets up exception levels, and prepares for handoff to UEFI.
TF-A is the ignition controller, launching the next stages securely.
TF-A hands off control to UEFI firmware (EDK II), which performs device discovery and launches GRUB.
Responsibilities here include:
EDK II and GRUB are like the first- and second-stage rockets launching the payload.
GRUB loads the Linux kernel and passes full control to the OS.
Responsibilities include:
The Linux kernel is the spacecraft - it takes over and begins its mission.
Now that you’ve examined the high-level boot stages, you can now examine each firmware module’s role in more detail.
Each stage of the boot chain is backed by a dedicated component, such as secure bootloader, platform controller, or OS manager, and they work together to ensure reliable system bring-up.
RSE firmware runs on the Cortex‑M55 and plays a critical role in platform attestation and integrity enforcement.
RSE acts as the second layer of the chain of trust, maintaining a monitored and secure environment throughout early boot.
TF-A establishes the system’s chain of trust and ensures downstream components are authenticated and loaded from trusted sources.
On the FVP you can see this process through UART logs to validate each stage.
If present, the LCP provides fine-grained platform power management:
LCP support depends on the FVP model and can be omitted in simplified setups.
The RD-V3 boot sequence follows a multi-stage, dependency-driven handshake model, where each firmware module validates, powers, or authorizes the next.
| Stage(s) | Dependency chain | Description |
| 1 | RSE ← BL2 | RSE is loaded and triggered by BL2 to begin security validation |
| 2 | SCP ← BL2 + RSE | SCP initialization requires BL2 and authorization from RSE |
| 3 | AP ← SCP + RSE | The AP starts only after SCP sets power and RSE permits |
| 4-5 | UEFI → GRUB → Linux | UEFI launches GRUB, which loads the kernel and enters the OS |
This handshake ensures no stage proceeds unless its dependencies have securely initialized and authorized the next step.
In the table, arrows (←) indicate dependency - the component on the left depends on the component(s) on the right to be triggered or authorized.
For example, RSE ← BL2 means BL2 loads/triggers RSE; AP ← SCP + RSE means the AP can start only after SCP has initialized hardware and RSE has granted authorization.
The right-facing arrows in UEFI → GRUB → Linux indicate a direct execution path—each stage passes control directly to the next.
This layered approach supports modular testing, independent debugging, and early simulation, which is essential for secure and robust platform bring-up.
In this section, you have:
With an understanding of the full boot sequence and firmware responsibilities, you’re ready to apply these insights. In the next section, you’ll fetch the RD-V3 codebase and start building the firmware stack for simulation.
