The underlying storage technology and the file system format can impact performance. In general, locally attached SSD storage will perform best. However, network based storage systems can perform well. You should spend some time studying and experimenting with different storage technologies and configuration options.
Aside from the storage technology, the file system format used with MySQL can impact performance. The xfs file system is a good starting point. The ext4 file system is another good alternative. Last, it is recommended to use storage drives that are dedicated to the database (i.e. not shared with the OS or other applications).
When running in the cloud, the disk scheduling algorithm is typically set to noop or a similar “dumb” algorithm. This is typically optimal for MySQL in the cloud, so no adjustment is needed. However, if running MySQL on an on-prem server, it’s a good idea to double check what the disk scheduling algorithm is, and possibly change it. According to the
Optimizing InnoDB Disk I/O documentation
, noop or deadline might be better options. It’s worth testing this with on-prem systems.
There are different storage engines available for MySQL. The default storage engine is InnoDB. InnoDB is the default storage engine because it performs the best in the broadest set of use cases.
Information on alternative storage engines can be found in the MySQL documentation .
MySQL can benefit from adjustments to kernel parameters. Below is a list of kernel related settings that can have a positive impact on performance.
Making changes to the Linux Virtual Memory subsystem can improve performance.
These settings can be changed in the /etc/sysctl.conf file, or by using the sysctl command.
Documentation on the virtual memory subsystem parameters can be found in the admin-guide for sysctl in the Linux source code .
To list all sysctl parameters available:
sudo sysctl -a
See the sysctl command documentation for more.
MySQL benefits from using huge memory pages. Huge pages reduce how often virtual memory pages are mapped to physical memory.
To see the current huge memory page configuration, run the following command on the host:
cat /proc/meminfo | grep ^Huge
The output should be similar to:
        HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
Hugetlb:               0 kB
Huge pages are not being used if HugePages_Total is 0 (this is typically the default).
Also note that Hugepagesize is 2MiB which is the typical default for huge pages on Linux.
The sysctl parameter that enables huge pages is shown below:
        vm.nr_hugepages
This parameter sets the number of huge pages you want the kernel to make available to applications.
The total amount of memory that will be used for huge pages will be this number (defaulted to 0) times the Hugepagesize.
As an example, if you want a total of 1GB of huge page space, then you should set vm.nr_hugepages to 500 (500x2MB=1GB).
sudo sysctl -w vm.nr_hugepages=500
To make the change permanent:
sudo sh -c 'echo "vm.nr_hugepages=500" >> /etc/sysctl.conf'
You should set vm.nr_hugepages to a value that gives a total huge page space equal to or slightly larger than the MySQL buffer pool size. Selecting the buffer pool size is discussed in the
Tuning MySQL
section.
Typically, only the number of huge pages needs to be configured. However, for more information on the different parameters that affect the configuration of huge pages, review the admin-guide for hugetlbpage in the Linux source code .
The easiest way to gain performance is to use the latest version of GCC. Aside from that, the flags -mcpu and -flto can be used to potentially gain additional performance. Usage of these flags is explained in the
Migrating C/C++ applications
section of the
Migrating applications to Arm servers
learning path.
MySQL relies on OpenSSL for cryptographic operations. Thus, the version of OpenSSL used with MySQL (and the GCC version and switches used to compile it) can impact performance. Typically using the Linux distribution default version of OpenSSL is sufficient.
However, it is possible to use newer versions of OpenSSL which could yield performance improvements. This is achieved by building and installing OpenSSL before building MySQL.
