Give feedback
AI-assisted
Close
How do I know a MySQL tuning change actually helped?
Run the same repeatable workload before and after the change and compare throughput, latency, and profiles. Change one parameter at a time or use a designed experiment so results are attributable to specific settings.
Should I set MySQL parameters in an option file or on the mysqld command line?
Use an option file for persistent tuning so changes are reviewable, version controlled, and applied on restart. The examples in the Learning Path target the [mysqld] group. Command-line flags are suitable for temporary tests.
Which storage option should I use when testing performance?
In general, locally attached SSD storage performs best, but network-based storage can also perform well. Test the storage technologies and file systems you have, and review disk scheduling behavior with your workload.
When should I look at kernel, compiler, or library choices instead of MySQL settings?
Evaluate them before or alongside MySQL tuning because operating system settings, kernel memory management, compiler choices, and library versions can affect throughput and latency. Treat them as part of the same performance experiment set.
How should I size huge pages for MySQL?
Enable huge pages for MySQL and size them based on the InnoDB buffer pool. This aligns page allocation with the primary memory consumer in typical MySQL deployments.
