You can build and run Sysbench on the second Arm Linux system to benchmark the MySQL server.
This system is called the client.
You will need at least 30 GB of disk space on the client system.
Because MySQL libraries are needed by Sysbench, you will need to build and install the MySQL server on the client system as well.
You do not need to configure and run MySQL, just the build and install steps.
Refer to Setup, configure, and run MySQL server to build and install MySQL server and provide the required libraries to Sysbench on the client system.
Use the commands below to build and install Sysbench:
git clone https://github.com/akopytov/sysbench
cd sysbench
Configure, build, and install Sysbench using:
./autogen.sh
./configure --with-mysql-includes=$HOME/mysql_install_8.0.33/include --with-mysql-libs=$HOME/mysql_install_8.0.33/lib
make -j $(nproc)
sudo make install
Make sure that port 3003 is open on the server system so that the Sysbench client can connect. If the machines are on the same local network, no action is needed. If you are using cloud instances, you will need to adjust the security group settings to open port 3003 for traffic originating from the client system.
To make it easier to run Sysbench, a script is provided below.
Using a text editor, copy the contents below into a file named run_sysbench.sh:
#!/bin/bash
die() {
echo $1
exit 1
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:mysql_install_8.0.33/lib # please replace it
SERVERIP=$1
MODE=$2 #oltp_write_only or oltp_read_only
#sync && echo 3 > /proc/sys/vm/drop_caches
WARMUP_TIME=60
RUN_TIME=300
NTHREAD=256
time=$(date "+%Y%m%d-%H:%M:%S")
echo "${time} $MODE Testing Ali config on mysql-8.0.25: nthread ${NTHREAD}"
sysbench $MODE \
--db-ps-mode=auto \
--mysql-host=$SERVERIP \
--mysql-port=3003 \
--mysql-user=sysbench \
--mysql-password=password \
--mysql-db=sysdb \
--tables=100 \
--table_size=400000 \
--time=300 \
--report-interval=1 \
--threads=64 \
cleanup || die "failed to cleanup"
echo "===> finish cleanup"
sleep 1
sysbench $MODE \
--db-ps-mode=auto \
--mysql-port=3003 \
--mysql-db=sysdb \
--tables=100 \
--time=300 \
--threads=64 \
prepare || die "failed to prepare"
echo "===> finish prepare"
sleep 1
sysbench $MODE \
--db-ps-mode=auto \
--mysql-port=3003 \
--mysql-db=sysdb \
--tables=100 \
--warmup-time=${WARMUP_TIME} \
--time=${RUN_TIME} \
--report-interval=10 \
--threads=${NTHREAD} \
run || die "failed to run"
echo "===> finish run"
sleep 1
Make the script executable:
chmod +x run_sysbench.sh
You can now start Sysbench by running the script.
Provide the IP address of the server system as the first argument and the mode as the second argument:
./run_sysbench.sh [MySQL-server-ip] [oltp_write_only | oltp_read_only]
The final output for the oltp_read_only test will be similar to:
SQL statistics:
queries performed:
read: 16015671
write: 0
other: 2288042
total: 18303713
transactions: 1144147 (3810.48 per sec.)
queries: 18303713 (60958.94 per sec.)
ignored errors: 0 (0.00 per sec.)
reconnects: 0 (0.00 per sec.)
Throughput:
events/s (eps): 3810.4831
time elapsed: 300.2631s
total number of events: 1144147
Latency (ms):
min: 5.91
avg: 67.14
max: 318.55
95th percentile: 78.60
sum: 76816641.30
Threads fairness:
events (avg/stddev): 4469.3086/284.51
execution time (avg/stddev): 300.0650/0.04
===> finish run
