You can run a MySQL server on an Arm Server with Ubuntu 22.04 installed, but other Linux distributions and Ubuntu versions may also work.
Follow the instructions below to build, install, configure, and run a MySQL server.
This system is called the server.
You will need at least 200 GB of disk space on the server system.
In order to build a MySQL server, install the following packages:
sudo apt install git make automake libtool bison pkg-config cmake g++ openssl libssl-dev libncurses5-dev libtirpc-dev rpcsvc-proto libaio-dev libssl-dev -y
MySQL server cannot be run as root.
You can create a MySQL user by using your own password instead of mysql*pw:
sudo useradd -s /bin/bash -m mysql && sudo adduser mysql sudo && echo "mysql:mysql*pw" | sudo chpasswd
Change to the mysql user and enter the password when prompted:
su - mysql
Boost is needed to build a MySQL server and to build MySQL server 8.0.33, we need boost_1_77_0.
Download Boost:
wget https://boostorg.jfrog.io/artifactory/main/release/1.77.0/source/boost_1_77_0.tar.gz && tar xzvf boost_1_77_0.tar.gz
Run the commands below to build and install a MySQL server:
git clone https://github.com/mysql/mysql-server && cd mysql-server
git checkout mysql-8.0.33
git submodule update --recursive
mkdir build ; cd build
cmake -DCMAKE_C_FLAGS="-g -O3 -march=native -mcpu=native -flto" -DCMAKE_CXX_FLAGS="-g -O3 -mcpu=native -flto" -DCMAKE_INSTALL_PREFIX=/home/mysql/mysql_install_8.0.33 -DWITH_BOOST=/home/mysql/boost_1_77_0/ ..
make -j $(nproc)
make -j $(nproc) install
To configure the MySQL server, you need to create a my.cnf config file.
Use a text editor to create a file named /home/mysql/mysql_install_8.0.33/my.cnf with the following contents:
[mysqld]
character_set_server = utf8
collation_server = utf8_general_ci
max_heap_table_size = 67108864
max_allowed_packet = 1073741824
thread_stack = 262144
interactive_timeout = 7200
wait_timeout = 86400
sort_buffer_size = 2097152
read_buffer_size = 1048576
read_rnd_buffer_size = 256K
join_buffer_size = 1048576
net_buffer_length = 16384
thread_cache_size = 100
ft_min_word_len = 4
transaction_isolation = READ-COMMITTED
tmp_table_size = 2097152
core-file
skip_name_resolve
skip_ssl
default_authentication_plugin = mysql_native_password
max_connections = 5000
max_user_connections = 5000
max_prepared_stmt_count = 1728000
binlog_cache_size = 1048576
max_binlog_size = 500M
sync_binlog = 1000
binlog_format = ROW
gtid_mode = ON
enforce-gtid-consistency = 1
innodb_flush_log_at_trx_commit = 2
innodb_buffer_pool_instances = 8
innodb_buffer_pool_size = 12884901888
innodb_file_per_table
innodb_log_buffer_size = 16M
innodb_log_file_size = 16384M
innodb_log_files_in_group = 2
innodb_max_dirty_pages_pct = 75
innodb_flush_method = O_DIRECT
innodb_lock_wait_timeout = 50
innodb_doublewrite = 1
innodb_rollback_on_timeout = OFF
innodb_autoinc_lock_mode = 2
innodb_purge_threads = 1
innodb_lru_scan_depth = 1024
innodb_open_files = 2000
table_open_cache = 2048
table_open_cache_instances = 8
innodb_read_io_threads = 4
innodb_write_io_threads = 4
innodb_io_capacity = 20000
innodb_io_capacity_max = 40000
autocommit = ON
innodb_deadlock_detect = ON
event_scheduler = OFF
performance_schema = OFF
loose_thread_pool_enabled = OFF
loose_thread_pool_size = 4
loose_innodb_rds_flashback_task_enabled = OFF
loose_innodb_undo_retention = 0
Run the commands below to start the MySQL server:
export MYSQL_HOME=/home/mysql/mysql_install_8.0.33
export MYSQL_BIN=$MYSQL_HOME/bin
export MYSQL_PLUGIN=$MYSQL_HOME/lib/plugin
export MYSQL_DATA=$MYSQL_HOME/data
export MYSQL_PORT=3003
rm -rf $MYSQL_DATA && mkdir $MYSQL_DATA
$MYSQL_BIN/mysqld --initialize-insecure --basedir=$MYSQL_HOME --datadir=$MYSQL_DATA --default_authentication_plugin=mysql_native_password --log-error-verbosity=3
$MYSQL_BIN/mysqld \
--defaults-file=$MYSQL_HOME/my.cnf \
--basedir=$MYSQL_HOME \
--datadir=$MYSQL_DATA \
--socket=$MYSQL_HOME/mysql.sock \
--port=$MYSQL_PORT \
--log-error=$MYSQL_HOME/log.err \
--log-error-verbosity=3 \
--secure-file-priv="" \
--plugin-dir=$MYSQL_PLUGIN \
--user=mysql \
2>&1 &
sleep 10 # make sure $MYSQL_HOME/mysql.sock is created
$MYSQL_BIN/mysql \
-S $MYSQL_HOME/mysql.sock \
-uroot \
-e "use mysql; \
update user set user.Host='%' where user.User='root'; \
FLUSH PRIVILEGES; \
CREATE DATABASE IF NOT EXISTS sysdb; \
create user sysbench@'%' identified by 'password'; \
grant all privileges on sysdb.* to sysbench@'%';"
If you want to stop the MySQL server after benchmarking is done, you can use the following commands:
$MYSQL_BIN/mysql -S $MYSQL_HOME/mysql.sock -uroot -e "DROP DATABASE sysdb;"
$MYSQL_BIN/mysqladmin -S $MYSQL_HOME/mysql.sock -uroot shutdown
