Migrate MySQL from on-premises x64 to Arm on Azure virtual machines
Understand Azure Cobalt 100 VMs and MySQL migration strategy
Create an Azure x64 virtual machine as an on-premises simulator
Prepare the on-premises source instance
Perform the lift-and-shift migration into Azure cloud
Benchmark MySQL performance on Azure Cobalt 100
Install system dependencies
SSH into your x64 on-premises VM. Then, run the following commands to update the system and install prerequisites for the migration scripts such as build tools, Python 3.10, and a Python virtual environment:
sudo apt update
sudo apt -y dist-upgrade
sudo apt install -y build-essential net-tools curl wget python3-dev python3-venv python3-pip openjdk-21-jdk apt-transport-https ca-certificates software-properties-common
sudo add-apt-repository -y ppa:deadsnakes/ppa
sudo apt update
sudo apt install -y python3.10-dev python3.10 python3.10-venv
python3.10 -m venv LnS
echo "source $HOME/LnS/bin/activate" >> $HOME/.bashrc
sudo reboot
Install MySQL, sysbench, Azure CLI, and Terraform
Log back in to the x64 on-premises server. Install MySQL Server and sysbench, then apply InnoDB tuning parameters suited to the VM size:
sudo apt install -y mysql-server
sudo apt install -y sysbench
echo innodb_buffer_pool_size = 16G | sudo tee -a /etc/mysql/mysql.conf.d/mysqld.cnf > /dev/null
echo innodb_flush_log_at_trx_commit = 2 | sudo tee -a /etc/mysql/mysql.conf.d/mysqld.cnf > /dev/null
echo innodb_log_file_size = 3G | sudo tee -a /etc/mysql/mysql.conf.d/mysqld.cnf > /dev/null
Install Azure CLI and Terraform. These tools are used later to provision the Arm-based target VM and run the migration:
curl -sL https://aka.ms/InstallAzureCLIDeb | sudo bash
curl -fsSL https://apt.releases.hashicorp.com/gpg | sudo gpg --dearmor -o /usr/share/keyrings/hashicorp-archive-keyring.gpg
echo "deb [signed-by=/usr/share/keyrings/hashicorp-archive-keyring.gpg] https://apt.releases.hashicorp.com $(lsb_release -cs) main" | sudo tee /etc/apt/sources.list.d/hashicorp.list
sudo apt update && sudo apt install terraform
sudo reboot
Confirm MySQL, Terraform, and Azure CLI installations
Open a new SSH shell into your x64 VM and confirm the MySQL client is available:
sudo mysql --version
The output is similar to:
mysql Ver 8.0.45-0ubuntu0.24.04.1 for Linux on x86_64 ((Ubuntu))
Confirm the Terraform installation version:
terraform --version
Terraform v1.14.8
on linux_amd64
Confirm the Azure CLI installation version:
az --version
azure-cli 2.85.0
core 2.85.0
telemetry 1.1.0
Dependencies:
msal 1.35.1
azure-mgmt-resource 24.0.0
Python location '/opt/az/bin/python3'
Config directory '/home/douans01/.azure'
Extensions directory '/home/douans01/.azure/cliextensions'
Python (Linux) 3.13.11 (main, Mar 31 2026, 07:18:38) [GCC 13.3.0]
Legal docs and information: aka.ms/AzureCliLegal
Your CLI is up-to-date.
Create a MySQL admin user
Create an admin user that the migration scripts will use to access the database. Connect to MySQL as root:
sudo mysql
At the MySQL prompt, run the following commands (example password: SuperStrongPassword):
CREATE USER 'admin'@'%' IDENTIFIED BY 'SuperStrongPassword';
GRANT ALL PRIVILEGES ON *.* TO 'admin'@'%' WITH GRANT OPTION;
FLUSH PRIVILEGES;
quit;
Now confirm that you can log into the MySQL environment with that admin user:
mysql -u admin -p
After you supply the password, you should see the MySQL prompt. Type quit; to exit.
Load the sample database
Clone the asset repository that contains the migration scripts and sample database:
cd $HOME
git clone https://github.com/DougAnsonAustinTX/lift-n-shift-assets
Restore the sample database into MySQL:
cd lift-n-shift-assets/testdb
gunzip -c testdb.sql.gz | mysql -h localhost -u admin -p
You’ve now prepared the on-premises x64 simulator with MySQL, sysbench, Terraform, and Azure CLI.
In the next section, you’ll run the migration workflow to move testdb to an Arm-based Azure VM.
