Download the migration scripts
Open an SSH shell into your on-premises instance and navigate to the asset repository you downloaded:
cd $HOME/lift-n-shift-assets
Configure the migration script
Run the following script to create an SSH key pair. Press the Enter key when prompted for a passphrase:
scripts/create_ssh_key.sh
The output is similar to:
        ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAACAQDczfgUuS4pnNSXnNeK4lRR+CcmxCH+/Vl+aP9dhtGYX7DEVrWrKy9Hq7AKs3y1AUyW85MGBJEkgy8WQZui6T92UNZz+MGVoKm/++SyO/
tH33RAoBg2q3mJJgOCqCQ8k5kfAww== azureuser@YOUR_X64_ON_PREM_HOST
Save this key. You’ll use it in the next step.
Create a copy of the terraform.tfvars.example to terraform.tfvars:
cp terraform.tfvars.example terraform.tfvars
In an editor, open terraform.tfvars:
location              = "eastus2"
prefix                = "mysql-migrate"
source_mysql_database = "testdb"
admin_username        = "azureadmin"
ssh_public_key        = "RSA_KEY_GOES_HERE"
allowed_ssh_cidr      = "YOUR_PUBLIC_IP/32"
allowed_mysql_cidr    = "YOUR_PUBLIC_IP/32"
allow_mysql_inbound = true
vm_size         = "Standard_E4pds_v6"
os_disk_size_gb = 48
tags = {
  environment = "prod"
  application = "testdb-migration"
  owner       = "admin"
  managed_by  = "terraform"
Edit the following:
  • location with the Azure region you want to use.
  • prefix to match your naming preference.
  • RSA_KEY_GOES_HERE with the SSH public key that you created. Make sure to include the ssh-rsa keyword as well within the RSA Key.
  • YOUR_PUBLIC_IP with the public IP address of your on-premises x64 instance.
You can leave the remaining values unchanged for this Learning Path.
Log in to Azure
On the on-premises SSH shell, run:
az login
Follow the prompts to log in to your Azure account.
Start the migration
scripts/migrate.sh testdb
This starts migration of the local testdb database into the Arm-based VM you configured in terraform.tfvars.
Assuming no errors in the tfvars config file, you’ll receive a prompt:
        Migrating local DB: testdb to Cloud...
Creating Cloud VM...
Cloud VM created.
Backing up the local DB testdb...
Enter password:
Enter the password you set for the local MySQL admin user in the previous section.
Cloud VM created.
Enter password:
You’ll now be prompted for a password again.
        Restoring local DB testdb onto the Cloud VM: Admin: admin IP: 20.98.229.225
You will need to open a second window and ssh into the VM and then look in /root for the password
Enter password:
To retrieve this password, follow these steps:
  1. Open another shell into your on-premises x64 instance.
  2. In that shell, check $HOME/.ssh and note the SSH private key filename ending in rsa.
  3. In the Azure portal, locate your new Arm-based VM under Virtual Machines.
  4. Record the VM public IP address.
  5. Back in the second on-premises shell, run the following command with your key filename and VM IP:
ssh -i $HOME/.ssh/YOUR_RSA_FILENAME azureadmin@YOUR_ARM_BASED_VM_PUBLIC_IP_ADDRESS
You should now have a shell on the Arm-based Azure VM. In that shell, run:
sudo su -
cat /root/mysql_root_password.txt
This is the required password. Provide it in your first SSH session on the on-premises host and let the script continue:
Cloud VM created.
Enter password:
Enter password:
Note
The original script may time out waiting for this second password. If it does, in the same shell, run the following command by replacing YOUR_ARM_BASED_VM_PUBLIC_IP_ADDRESS with the public IP address of your newly created Arm-based VM:
gunzip -c testdb.sql.gz | mysql -h YOUR_ARM_BASED_VM_PUBLIC_IP_ADDRESS -u admin -p
You’ll be prompted again for the second password you retrieved previously. Enter it to complete the migration.
At this point, your on-premises MySQL database (testdb) has been migrated to a new Arm-based VM in Azure.
You’ve now run a script and followed a procedure to migrate a MySQL database from an on-premises x64 source to an Arm-based Azure VM.
In the next section, you’ll benchmark the testdb database with sysbench in the target environment.
