Give feedback
AI-assisted
Close
Which architecture should I choose for the on-premises simulator VM?
Choose x64 for the simulator VM. It acts as the on-premises MySQL source that you migrate from.
Where do I run the migration scripts, and what SSH key do they generate?
Open an SSH shell on your on-premises x64 simulator and run the scripts from $HOME/lift-n-shift-assets. Run scripts/create_ssh_key.sh to generate an SSH key pair in $HOME/.ssh and print the public key. Press Enter to leave the passphrase empty, and save the printed ssh-rsa public key string for use with the Azure VM.
Where can I find the password requested when restoring the database on the cloud VM?
Open a second SSH session to the Arm-based Azure VM. Run sudo su -, then cat /root/mysql_root_password.txt to retrieve the password. Enter it at the restore prompt in your original session on the on-premises simulator.
How do I connect to the Arm-based Azure VM before running the benchmark?
From the on-premises simulator, SSH to the VM using the key created in $HOME/.ssh and the azureadmin user at the VM’s public IP.
Where should I create and run the benchmarking script, and what result should I expect?
Create and run the script, for example run.sh, on the Arm-based Azure VM after connecting with SSH. Expect sysbench to produce a summary of performance metrics that you can review to validate the migrated database.
