Use the built-in mysqlslap tool to understand how MySQL performs on Azure Cobalt 100 (Arm64) VMs.
mysqlslap is the official MySQL benchmarking tool used to simulate multiple client connections and measure query performance. It helps evaluate read/write throughput, query response times, and overall MySQL server performance under different workloads, making it ideal for baseline testing and optimization.
Set up up MySQL benchmarking with these steps.
Before running mysqlslap, you will create a dedicated test database so that benchmarking doesn’t interfere with your application data. This ensures clean test results and avoids accidental modifications to production schemas.
Connect to MySQL using the admin user:
mysql -u admin -p
Once logged in, create a benchmarking database:
CREATE DATABASE benchmark_db;
USE benchmark_db;
With a dedicated benchmark_db created, the next step is to define a test table and populate it with data. This simulates a realistic workload so that mysqlslap can measure query performance against non-trivial datasets.
Create a benchmark table:
CREATE TABLE benchmark_table (
record_id INT AUTO_INCREMENT PRIMARY KEY,
username VARCHAR(50),
score INT
To quickly verify that inserts work correctly and test small queries, run the following command inside the MySQL shell:
INSERT INTO benchmark_table (username,score) VALUES
('John',100),('Jane',200),('Mike',300);
This verifies that inserts work correctly and allows you to test small queries.
For benchmarking, larger datasets give more meaningful results. Use a stored procedure to generate rows programmatically:
DELIMITER //
CREATE PROCEDURE populate_benchmark_data()
BEGIN
DECLARE i INT DEFAULT 1;
WHILE i <= 1000 DO
INSERT INTO benchmark_table (username, score)
VALUES (CONCAT('Player', i), i*10);
SET i = i + 1;
END WHILE;
END //
DELIMITER ;
CALL populate_benchmark_data();
DROP PROCEDURE populate_benchmark_data;
At this stage, you have a populated benchmark_table inside benchmark_db. This provides a realistic dataset for running mysqlslap, enabling you to measure how MySQL performs on Azure Cobalt 100 under read-heavy, write-heavy, or mixed workloads.
With the benchmark_table populated, you can run a synthetic workload using mysqlslap to simulate multiple clients performing inserts or queries at the same time. This tests how well MySQL handles concurrent connections and query execution.
Use the following command:
mysqlslap --user=admin --password=`MyStrongPassword!` --host=127.0.0.1 --concurrency=10 --iterations=5 --query="INSERT INTO benchmark_db.benchmark_table (username,score) VALUES('TestUser',123);" --create-schema=benchmark_db
The table below provides descriptions of the options used:
| Option | Description | Example Value |
--user / --password | MySQL login credentials | admin / MyStrongPassword! |
--host | MySQL server address (use 127.0.0.1 for local) | 127.0.0.1 |
--concurrency | Number of simultaneous clients | 10 |
--iterations | Number of times to repeat the test | 5 |
--query | SQL statement to run repeatedly | INSERT ... or SELECT ... |
--create-schema | Database in which to run the query | benchmark_db |
You should see output similar to:
Benchmark
Average number of seconds to run all queries: 0.267 seconds
Minimum number of seconds to run all queries: 0.265 seconds
Maximum number of seconds to run all queries: 0.271 seconds
Number of clients running queries: 10
Average number of queries per client: 1
Run the following command to simulate multiple clients querying the table concurrently and record the results:
mysqlslap --user=admin --password="MyStrongPassword!" --host=127.0.0.1 --concurrency=10 --iterations=5 --query="SELECT * FROM benchmark_db.benchmark_table WHERE record_id < 500;" --create-schema=benchmark_db --verbose | tee -a /tmp/mysqlslap_benchmark.log
Benchmark
Average number of seconds to run all queries: 0.263 seconds
Minimum number of seconds to run all queries: 0.261 seconds
Maximum number of seconds to run all queries: 0.264 seconds
The following table lists the benchmark metrics with accompanying definitions.
| Metric | Description |
| Average number of seconds to run all queries | The average time it took for all the queries in one iteration to complete across all clients. It gives you a quick sense of overall performance. |
| Minimum number of seconds to run all queries | The fastest time any iteration of queries took. |
| Maximum number of seconds to run all queries | The slowest time any iteration of queries took. The closer this is to the average, the more consistent your performance is. |
| Number of clients running queries | Indicates how many simulated users (or connections) ran queries simultaneously during the test. |
| Average number of queries per client | Shows the average number of queries each client executed in the benchmark iteration |
Here is a summary of benchmark results collected on an Arm64 D4ps_v6 Ubuntu Pro 24.04 LTS virtual machine.
| Query Type | Average Time (s) | Minimum Time (s) | Maximum Time (s) | Clients | Avg Queries per Client |
| INSERT | 0.267 | 0.265 | 0.271 | 10 | 1 |
| SELECT | 0.263 | 0.261 | 0.264 | 10 | 1 |
The benchmark results on the Azure Cobalt 100 Arm64 VM show:
INSERT and SELECT queries performed consistently, with average times of 0.267s and 0.263s respectively.MySQL on Azure Cobalt 100 Arm64 VMs provides reliable and steady performance for both data insertion and retrieval tasks, making it suitable for applications requiring dependable database operations.
