Deploy MySQL on Microsoft Azure Cobalt 200 processors
Use a general-purpose Dpsv7 series instance based on Azure Cobalt 200, and choose Ubuntu 24.04 LTS as the base image.
Use the private SSH key that you downloaded when you created the VM, along with the administrator username and the VM’s public IP address.
Start MySQL and enable it to start on boot using the provided
systemctl commands. Then, perform the functional validation to confirm queries run and users can authenticate.Use the interactive script to review password validation and remove anonymous users. You can also disable remote root access, remove test databases, and reload the privilege tables. On Ubuntu, retain socket authentication for root and administer MySQL with
sudo mysql.Connect to MySQL and create the sample database and table before benchmarking.
mysqlslap simulates multiple clients and reports timing statistics that you can use as your baseline.
