You now have a workload running on an amd64 cluster and and can now evaluate the benefits of migrating to Arm.
This section shows you how to add an Arm-based node pool to the cluster, and apply an Ollama Arm deployment and service, mirroring what you did with the previous amd64 setup.
To add Arm nodes to the cluster:
arm64-pool.1.
To compare amd64 and arm64 performance, the c4a-standard-4 is used as the arm64 equivalent of the previously-deployed c4-standard-8 in the amd64 node pool.
Notice the default NoSchedule taint applied by GKE to Arm nodes with arch=arm64:
Without a toleration for this taint, you won’t be able to schedule any workloads on it. The nodeSelector in the amd64 (and as you will shortly see, the arm64) deployment YAMLs not only defines which architecture to target, but in the arm64 use case , it also adds the required toleration automatically.
nodeSelector:
kubernetes.io/arch: arm64
You can now apply the arm64-based deployment.
arm64_ollama.yaml:
apiVersion: apps/v1
kind: Deployment
metadata:
labels:
app: ollama-multiarch
namespace: ollama
spec:
replicas: 1
selector:
matchLabels:
arch: arm64
template:
metadata:
labels:
arch: arm64
spec:
nodeSelector:
containers:
- image: ollama/ollama:0.6.1
ports:
- containerPort: 11434
protocol: TCP
volumeMounts:
- mountPath: /root/.ollama
volumes:
- emptyDir: {}
apiVersion: v1
kind: Service
metadata:
namespace: ollama
spec:
sessionAffinity: None
ports:
- nodePort: 30666
port: 80
protocol: TCP
targetPort: 11434
selector:
arch: arm64
type: LoadBalancer
apiVersion: v1
kind: Service
metadata:
namespace: ollama
spec:
ports:
- nodePort: 30667
port: 80
protocol: TCP
targetPort: 11434
selector:
type: LoadBalancer
When the above is applied:
ollama-arm64-deployment is created. Like the amd64 deployment, it pulls the same multi-architecture image from DockerHub.Of particular interest is the nodeSelector kubernetes.io/arch, with the value of arm64. This ensures that the deployment runs on arm64-based nodes, utilizing the arm64 layer of the Ollama multi-architecture container image. The nodeSelector triggers the automatic creation of the toleration for the arm64 nodes.
ollama-arm64-svc is created, analogous to the existing service, and targets all pods with the arch: arm64 label (the arm64 deployment creates these pods). The second service, ollama-multiarch-svc, targets all pods, regardless of the architecture. This service shows how you can mix and match pods in production to serve the same application regardless of node/pod architecture.A sessionAffinity tag is added to this service to remove sticky connections to the target pods. This removes persistent connections to the same pod on each request.
kubectl apply -f arm64_ollama.yaml
You see the following responses:
deployment.apps/ollama-arm64-deployment created
service/ollama-arm64-svc created
service/ollama-multiarch-svc created
kubectl get nodes,pods,svc -nollama
Your output is similar to the following, showing two nodes, two pods, and three services:
NAME STATUS ROLES AGE VERSION
node/gke-ollama-on-arm-amd64-pool-62c0835c-93ht Ready <none> 91m v1.31.6-gke.1020000
node/gke-ollama-on-arm-arm64-pool-2ae0d1f0-pqrf Ready <none> 4m11s v1.31.6-gke.1020000
NAME READY STATUS RESTARTS AGE
pod/ollama-amd64-deployment-cbfc4b865-msftf 1/1 Running 0 29m
pod/ollama-arm64-deployment-678dc8556f-956d6 1/1 Running 0 2m52s
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
service/ollama-amd64-svc LoadBalancer 1.2.3.4 1.2.3.4 80:30668/TCP 29m
service/ollama-arm64-svc LoadBalancer 1.2.3.4 1.2.3.4 80:30666/TCP 2m52s
service/ollama-multiarch-svc LoadBalancer 1.2.3.4 1.2.3.4 80:30667/TCP 2m52s
When the pods show Running and the service shows a valid External IP, you are ready to test the Ollama arm64 service.
To test the service, use the previously created model_util.sh from the previous section.
Replace the amd64 parameter with arm64:
./model_util.sh arm64 hello
You get back the HTTP response, as well as the log line from the pod that served it:
Server response:
Using service endpoint 34.44.135.90 for hello on arm64
Ollama is running
Pod log output:
[pod/ollama-arm64-deployment-678dc8556f-956d6/ollama-multiarch] 2025-03-25T21:25:21.547384356Z
If you see the message “Ollama is running,” you have successfully set up your GKE cluster with both amd64 and arm64 nodes, each running a deployment using the Ollama multi-architecture container.
Continue to the next section to analyze the performance.
