# Deploy Ollama amd64 to the cluster
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/multiarch_ollama_on_gke/)
- [Create the GKE Cluster](https://learn.arm.com/learning-paths/servers-and-cloud-computing/multiarch_ollama_on_gke/0-spin_up_gke_cluster/)
- [Deploy Ollama amd64 to the cluster](https://learn.arm.com/learning-paths/servers-and-cloud-computing/multiarch_ollama_on_gke/1-deploy-amd64/)
- [Deploy Ollama arm64 to the cluster](https://learn.arm.com/learning-paths/servers-and-cloud-computing/multiarch_ollama_on_gke/2-deploy-arm64/)
- [Test functionality and performance](https://learn.arm.com/learning-paths/servers-and-cloud-computing/multiarch_ollama_on_gke/3-perf-tests/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/multiarch_ollama_on_gke/_next-steps/)
In this section, you’ll bootstrap the cluster with Ollama on amd64, simulating an existing Kubernetes (K8s) cluster running Ollama. In the next section, you’ll add arm64 nodes alongside the amd64 nodes for performance comparison.
1. Use a text editor to copy the following YAML and save it to a file called `namespace.yaml`:
   ```yaml
   apiVersion: v1
   kind: Namespace
   metadata:
   Applying this YAML creates a new namespace called `ollama`, which contains all subsequent K8s objects.
2. Use a text editor to copy the following YAML and save it to a file called `amd64_ollama.yaml`:
   ```yaml
   apiVersion: apps/v1
   kind: Deployment
   metadata:
     labels:
       app: ollama-multiarch
     namespace: ollama
   spec:
     replicas: 1
     selector:
       matchLabels:
         arch: amd64
     template:
       metadata:
         labels:
           arch: amd64
       spec:
         nodeSelector:
           kubernetes.io/arch: amd64
         containers:
         - image: ollama/ollama:0.6.1
           ports:
           - containerPort: 11434
             protocol: TCP
           volumeMounts:
           - mountPath: /root/.ollama
         volumes:
         - emptyDir: {}
   apiVersion: v1
   kind: Service
   metadata:
     namespace: ollama
   spec:
     sessionAffinity: None
     ports:
     - nodePort: 30668
       port: 80
       protocol: TCP
       targetPort: 11434
     selector:
       arch: amd64
     type: LoadBalancer
   When the above is applied:
   - A new deployment called `ollama-amd64-deployment` is created. This deployment pulls a multi-architecture [Ollama image](https://hub.docker.com/layers/ollama/ollama/0.6.1/images/sha256-28b909914d4e77c96b1c57dea199c60ec12c5050d08ed764d9c234ba2944be63) from DockerHub.
   - Of particular interest is the `nodeSelector` `kubernetes.io/arch`, with the value of `amd64`. This ensures that the deployment only runs on amd64 nodes, utilizing the amd64 version of the Ollama container image.
   - A new load balancer service `ollama-amd64-svc` is created, targeting all pods with the `arch: amd64` label (the amd64 deployment creates these pods).
   - A `sessionAffinity` tag is added to this service to remove sticky connections to the target pods. This removes persistent connections to the same pod on each request.
### Apply the amd64 deployment and service
1. Run the following commands to apply the namespace, deployment, and service definitions:
   ```bash
   kubectl apply -f namespace.yaml
   kubectl apply -f amd64_ollama.yaml
   You see the following responses:
   namespace/ollama created
   deployment.apps/ollama-amd64-deployment created
   service/ollama-amd64-svc created
2. Optionally, set the `default Namespace` to `ollama` to simplify future commands:
   ```bash
   kubectl config set-context --current --namespace=ollama
3. Get the status of nodes, pods and services by running:
   ```bash
   kubectl get nodes,pods,svc -nollama
   Your output should be similar to the following, showing one node, one pod, and one service:
   NAME                                              STATUS   ROLES    AGE   VERSION
   node/gke-ollama-on-arm-amd64-pool-62c0835c-93ht   Ready    <none>   77m   v1.31.6-gke.1020000
   NAME                                          READY   STATUS    RESTARTS   AGE
   pod/ollama-amd64-deployment-cbfc4b865-msftf   1/1     Running   0          16m
   NAME                       TYPE           CLUSTER-IP      EXTERNAL-IP    PORT(S)        AGE
   service/ollama-amd64-svc   LoadBalancer   1.2.2.3         1.2.3.4        80:30668/TCP   16m
   When the pods show `Running` and the service shows a valid `External IP`, you’re ready to test the Ollama amd64 service.
### Test the Ollama web service on amd64
> Note
> The following utility `model_util.sh` is provided for convenience.
> It’s a wrapper for kubectl, utilizing [curl](https://curl.se/), [jq](https://jqlang.org/), [bc](https://www.gnu.org/software/bc/), and [stdbuf](https://www.gnu.org/software/coreutils/manual/html_node/stdbuf-invocation.html).
> Make sure you have these shell utilities installed before running.
1. Use a text editor to copy the following shell script and save it to a file called `model_util.sh`:
   ```bash
   #!/bin/bash
   echo
   # https://ollama-operator.ayaka.io/pages/en/guide/supported-models
   model_name="llama3.2"
   #model_name="mistral"
   #model_name="dolphin-phi"
   #prompt="Name the two closest stars to earth"
   prompt="Create a sentence that makes sense in the English language, with as many palindromes in it as possible"
   echo "Server response:"
   get_service_ip() {
       arch=$1
       svc_name="ollama-${arch}-svc"
       kubectl -nollama get svc $svc_name -o jsonpath="{.status.loadBalancer.ingress[*]['ip', 'hostname']}"
   infer_request() {
       svc_ip=$1
       temp=$(mktemp)
       stdbuf -oL curl -s $temp http://$svc_ip/api/generate -d '{
           "model": "'"$model_name"'",
           "prompt": "'"$prompt"'"
       }' | tee $temp
       duration=$(grep eval_count $temp | jq -r '.eval_duration')
       count=$(grep eval_count $temp | jq -r '.eval_count')
       if [[ -n "$duration" && -n "$count" ]]; then
           quotient=$(echo "scale=2;1000000000*$count/$duration" | bc)
           echo "Tokens per second:  $quotient"
       else
           echo "Error: eval_count or eval_duration not found in response."
       fi
       rm $temp
   pull_model() {
       svc_ip=$1
       curl http://$svc_ip/api/pull -d '{
   hello_request() {
       svc_ip=$1
   run_action() {
       arch=$1
       action=$2
       svc_ip=$(get_service_ip $arch)
       echo "Using service endpoint $svc_ip for $action on $arch"
       case $action in
           infer)
               infer_request $svc_ip
           pull)
               pull_model $svc_ip
           hello)
               hello_request $svc_ip
               echo "Invalid second argument. Use 'infer', 'pull', or 'hello'."
               exit 1
       esac
   case $1 in
       arm64|amd64|multiarch)
           run_action $1 $2
           echo "Invalid first argument. Use 'arm64', 'amd64', or 'multiarch'."
           exit 1
   esac
   echo -e "\n\nPod log output:"
   echo;kubectl logs --timestamps  -l app=ollama-multiarch -nollama --prefix  | sort -k2 | cut -d " " -f 1,2 | tail -1
   echo
2. Make the script executable with the following command:
   ```bash
   chmod 755 model_util.sh
   The script conveniently bundles many test and logging commands into a single place, making it easy to test, troubleshoot, and view services.
3. Run the following to make an HTTP request to the amd64 Ollama service on port 80:
   ```bash
   ./model_util.sh amd64 hello
   You get back the HTTP response, as well as the log line from the pod that served it:
   Server response:
   Using service endpoint 34.55.25.101 for hello on amd64
   Ollama is running
   Pod log output:
   [pod/ollama-amd64-deployment-cbfc4b865-msftf/ollama-multiarch] 2025-03-25T21:13:49.022522588Z
   If you see the output `Ollama is running` you have successfully bootstrapped your GKE cluster with an amd64 node, running a deployment with the Ollama multi-architecture container instance.
Continue to the next section to do the same thing, but with an Arm node.
