Set up a multi-architecture AKS cluster
In this section, you’ll create a multi-architecture Azure Kubernetes Service (AKS) cluster that supports both Intel and Arm-based nodes. This setup allows you to deploy and compare workloads across different CPU architectures within the same Kubernetes environment.
You’ll work through three activities:
  • Set up authentication - you’ll connect to your Azure account using the Azure CLI
  • Create the cluster infrastructure - you’ll build an AKS cluster with two distinct node pools (one x86 and one Arm)
  • Verify connectivity - you’ll confirm your cluster is running and accessible using kubectl
This multi-architecture approach gives you the flexibility to run workloads optimized for specific CPU types while maintaining a unified Kubernetes management experience. By the end of this section, you’ll have a fully functional cluster ready for deploying containerized applications.
Create the cluster and resource
To begin, login to your Azure account using the Azure CLI:
az login
Once logged in, create the resource group and AKS cluster with two node pools:
  • One with Intel-based nodes (Standard_D2s_v6)
  • One with Arm-based nodes (Standard_D2ps_v6)
Note
This Learning Path uses the westus2 region because it supports both Intel and Arm VM sizes. You can use a different region, but make sure it supports both VM types and AKS.
Set the environment variables as shown below and run the az aks commands on your command line:
# Set environment variables
export RESOURCE_GROUP=nginx-on-arm-rg
export LOCATION=westus2
export CLUSTER_NAME=nginx-on-arm
# Create resource group
az group create --name $RESOURCE_GROUP --location $LOCATION
# Create AKS cluster with Intel node pool in zone 2
az aks create \
  --resource-group $RESOURCE_GROUP \
  --name $CLUSTER_NAME \
  --location $LOCATION \
  --zones 2 \
  --node-count 1 \
  --node-vm-size Standard_D2s_v6 \
  --nodepool-name intel \
  --generate-ssh-keys
# Add ARM node pool in zone 2
az aks nodepool add \
  --cluster-name $CLUSTER_NAME \
  --name arm \
  --zones 2 \
  --node-count 1 \
  --node-vm-size Standard_D2ps_v6
Each command returns JSON output with status information. Look for "provisioningState": "Succeeded" in each response to confirm the operation completed successfully.
Connect to the cluster
Verify kubectl is available by running:
kubectl version --client
The output should look similar to:
        Client Version: v1.34.1
Kustomize Version: v5.7.1
If kubectl is installed the version information is printed. If you don’t see the version information printed, refer to the Azure CLI Install Guide and kubectl Install Guide .
Next, set up your newly-created K8s cluster credentials using the Azure CLI:
az aks get-credentials --resource-group $RESOURCE_GROUP --name $CLUSTER_NAME
The expected output is:
        Merged "nginx-on-arm" as current context in /home/user/.kube/config
Now verify you’re connected to the cluster:
kubectl cluster-info
        Kubernetes control plane is running at https://nginx-on-a-nginx-on-arm-rg-dd0bfb-eenbox6p.hcp.westus2.azmk8s.io:443
With the cluster running, verify the node pools are ready:
kubectl get nodes -o wide
You should see output similar to:
        NAME                            STATUS   ROLES    AGE    VERSION
aks-arm-13087205-vmss000002     Ready    <none>   6h8m   v1.32.7
aks-intel-39600573-vmss000002   Ready    <none>   6h8m   v1.32.7
With all nodes showing Ready status, you’re now ready to continue to the next section.
Great job! You’ve successfully created a multi-architecture AKS cluster with both Arm and x64 node pools. This is a significant milestone and you’re now set up to deploy and compare workloads across architectures. Keep going to see your cluster in action!
