You now have nginx running on Intel and Arm nodes with architecture-specific services. In this section, you’ll create a multi-architecture service that can route to any available nginx pod regardless of architecture, providing load balancing across both architectures.
The multiarch service targets all pods with the app: nginx-multiarch label (all nginx deployments share this label). It uses sessionAffinity: None to ensure requests are distributed across all available pods without stickiness, and can route to Intel or Arm pods based on availability and load balancing algorithms.
Run the following commands to download and apply the multiarch service:
curl -sO https://raw.githubusercontent.com/geremyCohen/nginxOnAKS/main/multiarch_nginx.yaml
kubectl apply -f multiarch_nginx.yaml
You see the following response:
service/nginx-multiarch-svc created
Next, get the status of all services by running:
kubectl get svc -nnginx
Your output should be similar to the following, showing three services:
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
nginx-arm-svc LoadBalancer 10.0.241.154 48.192.64.197 80:30082/TCP 7m52s
nginx-intel-svc LoadBalancer 10.0.226.250 20.80.128.191 80:30080/TCP 16m
nginx-multiarch-svc LoadBalancer 10.0.40.169 20.99.208.140 80:30083/TCP 38s
Check which pods the multiarch service can route to:
kubectl get endpoints nginx-multiarch-svc -nnginx
You should see both architecture pods listed as endpoints:
NAME ENDPOINTS AGE
nginx-multiarch-svc 10.244.0.21:80,10.244.1.1:80 47s
You are ready to test the multiarch service.
Run the following to make HTTP requests to the multiarch nginx service:
./nginx_util.sh curl multiarch
You get back the HTTP response from one of the available pods:
Using service endpoint 20.99.208.140 for curl on multiarch service
Response:
"message": "nginx response",
"timestamp": "2025-10-24T22:12:23+00:00",
"server": "nginx-arm-deployment-5bf8df95db-wznff",
"request_uri": "/"
Served by: nginx-arm-deployment-5bf8df95db-wznff
Run the command multiple times to see load balancing across architectures:
The responses will show requests being served by different architecture deployments (Intel or Arm), demonstrating that the multiarch service distributes the load across the available pods.
Now you can compare the behavior:
The architecture-specific services provide predictable routing patterns. When you run ./nginx_util.sh curl intel, your requests consistently reach Intel-based pods. Similarly, ./nginx_util.sh curl arm ensures your traffic goes to Arm-based pods.
In contrast, the multiarch service distributes requests across all available pods regardless of architecture. This means ./nginx_util.sh curl multiarch might connect you to either an Intel or Arm pod depending on current load and availability.
Excellent work! You’ve successfully created a multi-architecture service that intelligently distributes traffic across both Arm and Intel pods. This unified service approach provides high availability and load distribution across your entire multi-architecture cluster, giving you the flexibility to leverage the strengths of different CPU architectures within a single Kubernetes environment.
You now have a complete multi-architecture deployment with three different service routing patterns: architecture-specific services for targeted testing, and a multiarch service for production-grade load balancing. You’re ready to move on to performance monitoring and comparison.
