Now that you have all your nginx deployments running across Intel and Arm architectures, you can monitor performance across each architecture using wrk to generate load and btop to monitor system performance.
This Learning Path uses
wrk
to generate HTTP load testing. You can easily install wrk using apt or brew package managers.
If you prefer alternatives like
wrk2
(a modern fork with additional features) or other HTTP load generators, you can use those instead.
Run the following command to apply the configuration updates:
./nginx_util.sh put btop
You will see output similar to the following:
Installing btop on all nginx pods...
Installing btop on nginx-amd-deployment-56b547bb47-vgbjj...
✓ btop installed on nginx-amd-deployment-56b547bb47-vgbjj
Installing btop on nginx-arm-deployment-66cb47ddc9-fgmsd...
✓ btop installed on nginx-arm-deployment-66cb547ddc9-fgmsd
Installing btop on nginx-intel-deployment-6f5bff9667-zdrqc...
✓ btop installed on nginx-intel-deployment-6f5bff9667-zdrqc
✅ btop installed on all pods!
The nginx_util.sh script includes a put config command that:
btop monitoring tool on all pods for system monitoringCheck that all pods have restarted with the new configuration:
kubectl get pods -n nginx
You should see all pods with recent restart times.
Because pods are ephemeral, you need to reinstall btop if pods restart or get deleted. If you see a “btop not found” error, run ./nginx_util.sh put btop again to reinstall it.
You can now log in to any pod and monitor system performance with btop. Many factors can affect workload performance, and btop (like top) is an excellent starting point for understanding these metrics.
Network performance can impact load testing accuracy when running from your local machine. If you experience low request rates (under 70,000 requests/s), consider running the test from an Azure VM in the same region as your cluster.
You can create an
Azure VM instance
and install the nginx_util.sh script there for more reliable results.
Running two btop terminals, one for each pod, is a convenient way to view performance in real time.
To bring up btop on both Arm and Intel pods, follow these steps:
login arm from the nginx utility script to enter the podlogin intel from the nginx utility script to enter the podbtop to see real-time system monitoringThe commands are shown below.
For the Arm terminal:
./nginx_util.sh login arm
For the Intel terminal:
./nginx_util.sh login intel
In both terminals run:
btop --utf-force
You should now see something similar to the image below, with one terminal for each Arm and Intel pod running btop:
To visualize performance with btop against the Arm and Intel pods using the load balancer service endpoints, you can use the nginx_util.sh wrapper to generate load to both simultaneously:
./nginx_util.sh wrk both
This runs wrk with predefined settings (1 thread, 50 simultaneous connections) to generate load to the K8s architecture-specific endpoints.
While it runs (for a default of 30s), you can observe some performance characteristics from the btop outputs:
You can observe several performance characteristics from the btop outputs during load testing. Pay attention to the memory and CPU resource usage for each pod:
These real-time metrics help you compare how each architecture handles the load and resource consumption patterns.
In addition to the visual metrics, the script also returns runtime results including requests per second and latencies:
Running wrk against both architectures in parallel...
Intel: wrk -t1 -c50 -d30 http://172.193.227.195/
ARM: wrk -t1 -c50 -d30 http://20.252.73.72/
INTEL RESULTS:
Running 30s test @ http://172.193.227.195/
1 threads and 50 connections
Thread Stats Avg Stdev Max +/- Stdev
Latency 752.40us 1.03ms 28.95ms 94.01%
Req/Sec 84.49k 12.14k 103.08k 73.75%
2528743 requests in 30.10s, 766.88MB read
Requests/sec: 84010.86
Transfer/sec: 25.48MB
ARM RESULTS:
Running 30s test @ http://20.252.73.72/
Latency 621.56us 565.90us 19.75ms 95.43%
Req/Sec 87.54k 10.22k 107.96k 82.39%
2620567 requests in 30.10s, 789.72MB read
Requests/sec: 87062.21
Transfer/sec: 26.24MB
Both tests completed
The nginx_util.sh script shows the results of the load generation, as well as the command lines used to generate them.
Feel free to experiment with by increasing and decreasing client threads, connections, and durations to better understand the performance characteristics under different scenarios.
For example, to generate load using 500 connections across 4 threads to the Arm service for 5 minutes (300s), you can use the following command:
wrk -t4 -c500 -d300 http://20.252.73.72/
You have successfully deployed and monitored nginx workloads across both Arm and Intel architectures on Azure Kubernetes Service. You’ve learned how to generate load with wrk, monitor real-time performance with btop, and compare performance characteristics between different architectures.
You now have the knowledge to experiment with your own workloads on Arm-based AKS nodes to identify performance and efficiency opportunities unique to your own environments. Here are some ideas for further exploration:
Congratulations on completing this Learning Path! You’ve built a solid foundation for deploying and optimizing multi-architecture Kubernetes workloads on Azure, positioning yourself to take full advantage of Arm’s performance and cost benefits in your cloud infrastructure.
