In the development of Libamath, a metric called ULP error is used to assess the accuracy of floating-point functions. ULP (Unit in the Last Place) measures the distance between two numbers, a reference (want) and an approximation (got), relative to how many floating-point steps (ULPs) separate them.
The formula is:
ulp_err = | want - got | / ULP(want)
Because ULP error is defined in terms of floating-point spacing, it is inherently scale-aware. In contrast to absolute error, ULP error avoids bias due to the uneven distribution of floating-point numbers across different magnitudes.
In practice, the basic expression is modified to account for additional sources of error introduced during the computation itself.
In the implementation used here, this quantity is held by a term called tail:
ulp_err = | (got - want) / ULP(want) - tail |
This term compensates for the rounding error that occurs when the high-precision reference (want_l, a double) is cast down to a float. This contribution is given in terms of ULP distance:
tail = | (want_l - want) / ULP(want) |
Below is a practical implementation of the ULP error calculation based on the model above. Use the same ulp.h header from the previous section.
Use a text editor to copy the code below into a new file called ulp_error.h:
// Defines ulpscale(x)
#include "ulp.h"
// Compute ULP error given:
// - got: computed result -> got (float)
// - want_l: high-precision reference -> want (double)
double ulp_error(float got, double want_l) {
float want = (float) want_l;
// Early exit for exact match
if ((want_l == (double) want && got == want)) {
return 0.0;
int ulp_exp = ulpscale(want); // Base-2 exponent for scaling ULP(want)
// Fractional tail from float rounding
double tail = scalbn(want_l - (double)want, -ulp_exp);
// Difference between computed and rounded reference
double diff = (double)got - (double)want;
// Return total ULP error with bias correction
return fabs(scalbn(diff, -ulp_exp) - tail);
The final scaling is done with respect to the rounded reference.
In this implementation, it is possible to get exactly 0.0 ULP error if and only if:
want_l, a double) is exactly representable as a float, andgot) is bitwise equal to that float representation.Below is a small example to check this implementation.
Save the code below into a file named ulp_error.c.
#include <stdio.h>
#include "ulp_error.h"
int main() {
float got = 1.0000001f;
double want_l = 1.0;
double ulp = ulp_error(got, want_l);
printf("ULP error: %f\n", ulp);
return 0;
Compile the program with GCC.
gcc -O2 ulp_error.c -o ulp_error
Run the program:
./ulp_error
The output should be:
ULP error: 1.0
If you are interested in diving into the full implementation of the ULP error, you can consult the tester tool in AOR , with particular focus to the ulp.h file. Note this tool also handles special cases and considers the effect of different rounding modes in the ULP error.
