Libamath provides multiple accuracy modes for the same vectorized mathematical function, allowing developers to choose between speed and precision depending on workload requirements.
Some functions offer selectable modes with tradeoffs between:
You can recognize the accuracy mode of a function by the suffix in the function symbol:
_u10 → High accuracy
Example: armpl_vcosq_f32_u10
Ensures results within 1 Unit in the Last Place (ULP).
(no suffix) → Default accuracy
Keeps errors within 3.5 ULP - balancing precision and performance.
_umax → Low accuracy/max performance
Example: armpl_vcosq_f32_umax
Prioritizes speed, tolerating errors up to 4096 ULP, or roughly 11 correct bits in single-precision.
Selecting an appropriate accuracy level helps avoid unnecessary compute cost while preserving output quality where it matters.
Use when bit-level correctness matters. These routines employ advanced algorithms (such as high-degree polynomials, tight range reduction, or FMA usage) and are ideal for:
While slower, these functions provide near-bitwise reproducibility — critical for validation and scientific fidelity.
The default mode strikes a practical balance between performance and numerical fidelity. It’s optimized for:
Also suitable for many scientific workloads that can tolerate modest error in exchange for faster throughput.
This mode trades precision for speed — aggressively. It’s designed for:
Avoid in control-flow-critical code or where errors might compound or affect control flow.
| Accuracy Mode | Libamath example | Approx. Error | Performance | Typical Applications |
_u10 | _ZGVnN4v_cosf_u10 | ≤1.0 ULP | Low | Scientific computing, backpropagation, validation |
| (default) | _ZGVnN4v_cosf | ≤3.5 ULP | Medium | General compute, analytics, inference |
_umax | _ZGVnN4v_cosf_umax | ≤4096 ULP | High | Real-time graphics, DSP, approximations, simulations |
If your workload has mixed precision needs, you can selectively call different accuracy modes for different parts of your pipeline. Choose conservatively where correctness matters, and push for speed elsewhere.
Higham, N. J. (2002). Accuracy and Stability of Numerical Algorithms (2nd ed.), SIAM.
Texas Instruments. Overflow Avoidance Techniques in Cascaded IIR Filter Implementations on the TMS320 DSPs. Application Report SPRA509, 1999. https://www.ti.com/lit/pdf/spra509
Ma, S., & Huai, J. (2019). Approximate Computation for Big Data Analytics. arXiv:1901.00232. https://arxiv.org/pdf/1901.00232
Gupta, S., Agrawal, A., Gopalakrishnan, K., & Narayanan, P. (2015). Deep Learning with Limited Numerical Precision. In Proceedings of the 32nd International Conference on Machine Learning (ICML), PMLR 37. https://proceedings.mlr.press/v37/gupta15.html
Unity Technologies. Precision Modes. Unity Shader Graph Documentation.
https://docs.unity3d.com/Packages/com.unity.shadergraph@17.1/manual/Precision-Modes.html
Croci, M., Gorman, G. J., & Giles, M. B. (2021). Rounding Error using Low Precision Approximate Random Variables. arXiv:2012.09739. https://arxiv.org/abs/2012.09739
