Give feedback
AI-assisted
Close
How do I recognize which Libamath accuracy mode a function uses?
Check the function symbol suffix. The _u10 suffix selects high accuracy with a 1 ULP bound, no suffix selects default accuracy, and _umax selects maximum performance.
What ULP error bounds should I expect for each mode?
Compare your measured error with these limits: high accuracy is at most 1 ULP, default accuracy is at most 3.5 ULP, and low accuracy is approximately at most 4,096 ULP.
What result should I expect when running the example?
Confirm that the program calls the Neon single-precision exponential function in each mode and reports an error calculated by ulp_error.h. Each value should remain within its documented ULP bound.
What should I check if the example can’t find amath.h or float32x4_t?
Confirm that Arm Performance Libraries 25.04 or later is installed and that your build uses the correct include paths. Compile on an Arm system so that the example’s vector types and calling convention are available.
How is ULP computed, and why use it instead of absolute error?
Calculate ULP(x) as nextafter(x, +inf) - x, which gives the spacing to the next representable value. ULP error scales with magnitude, so you avoid the bias that absolute error can introduce across different ranges.
