This section shows you how to install MongoDB and the MongoDB Shell (mongosh) on an Arm-based Google Axion C4A instance running Red Hat Enterprise Linux. You will download the Arm64 binaries, update your environment, and verify that the database server runs correctly.
Install the required system packages:
sudo dnf update -y
sudo dnf install -y libcurl openssl tar wget curl
Download and extract MongoDB
Fetch and unpack the MongoDB Arm64 (aarch64) binaries for RHEL 9.3:
```console
wget https://fastdl.mongodb.org/linux/mongodb-linux-aarch64-rhel93-8.0.12.tgz
tar -xzf mongodb-linux-aarch64-rhel93-8.0.12.tgz
ls mongodb-linux-aarch64-rhel93-8.0.12/bin
Add the binaries to your PATH so they are available in every shell session:
echo 'export PATH=~/mongodb-linux-aarch64-rhel93-8.0.12/bin:$PATH' >> ~/.bashrc
source ~/.bashrc
Create a data directory for MongoDB files:
mkdir -p ~/mongodb-data/db
Start mongod in the foreground to verify that it launches and to view logs directly:
mongod --dbpath ~/mongodb-data/db
Starting the server in the foreground allows you to see real-time logs and is useful for debugging or verifying that MongoDB starts correctly. However, this will occupy your terminal and stop the server if you close the terminal or interrupt it.
Stop the server (for example, with Ctrl+C), then confirm that data files were created:
ls ~/mongodb-data/db/
Example output:
collection-0-7680310461694759627.wt index-3-7680310461694759627.wt mongod.lock WiredTiger.lock
Once you’ve confirmed it’s working, you can start MongoDB in the background using the --fork option and redirecting logs to a file. This allows MongoDB to run continuously without tying up your terminal session.
Start mongod in the background with logging enabled so it continues to run after you close the terminal:
mongod --dbpath ~/mongodb-data/db --logpath ~/mongodb-data/mongod.log --fork
mongosh is the MongoDB shell used to interact with your database. Download and install mongosh for Arm64:
wget https://github.com/mongodb-js/mongosh/releases/download/v2.5.6/mongodb-mongosh-2.5.6.aarch64.rpm
sudo dnf install -y ./mongodb-mongosh-2.5.6.aarch64.rpm
Verify the installation:
mongosh --version
Connect to the local server:
mongosh mongodb://127.0.0.1:27017
Sample output:
Connecting to: mongodb://127.0.0.1:27017/?directConnection=true&...
Using MongoDB: 8.0.12
Using Mongosh: 2.5.6
test>
With MongoDB and mongosh successfully installed and running, you’re now ready to proceed with baseline testing.
