This section walks you through creating a Google Axion C4A Arm virtual machine on GCP with the c4a-standard-4 (4 vCPUs, 16 GB Memory) machine type, using the Google Cloud Console.
If you haven’t set up a Google Cloud account, see the Learning Path Getting started with Google Cloud Platform .
To create a VM based on the C4A Arm architecture:
C4A.c4a-standard-4.
Selecting the C4A series and c4a-standard-4 machine typeDo not leave Allow HTTP traffic enabled permanently. For long-term use, restrict access to only the IP addresses you need.
To open a shell on the VM, select SSH in the instance details page. Use this terminal for the commands in the next sections, where you will install and configure MongoDB on your Axion C4A instance.
