YCSB (Yahoo! Cloud Serving Benchmark) is an open-source tool for evaluating NoSQL databases under various workloads. It simulates operations such as writes, updates, and scans to mimic production traffic.
Install build tools and clone YCSB, then build the MongoDB binding:
sudo dnf install -y git maven java-11-openjdk-devel
git clone https://github.com/brianfrankcooper/YCSB.git
cd YCSB
mvn -pl site.ycsb:mongodb-binding -am clean package
## Load initial data
Load a starter dataset (defaults to 1,000 records) into MongoDB:
```console
./bin/ycsb load mongodb -s \
-P workloads/workloada \
-p mongodb.url=mongodb://127.0.0.1:27017/ycsb
This prepares the database for the performance test.
Run Workload A (50% reads, 50% updates) and collect metrics:
./bin/ycsb run mongodb -s \
Workload A is a balanced workload:
This simulates common real-world applications like session stores or shopping carts.
Sample output:
[READ], Operations, 534
[READ], AverageLatency(us), 312.96
[READ], MinLatency(us), 156
[READ], MaxLatency(us), 8279
[UPDATE], Operations, 466
[UPDATE], AverageLatency(us), 384.45
[UPDATE], MinLatency(us), 186
[UPDATE], MaxLatency(us), 26543
[OVERALL], RunTime(ms), 512
[OVERALL], Throughput(ops/sec), 1953.125
With YCSB installed and benchmark results captured, you now have a baseline for MongoDB’s performance under mixed workloads.
To better understand how MongoDB behaves across architectures, YCSB benchmark workloads were run on both an x86_64 (C3 Standard) and an Arm64 (C4A Standard) virtual machine, each with 4 vCPUs and 16 GB of memory, running RHEL 9.
Results from a c3-standard-4 instance (4 vCPUs, 16 GB RAM) on RHEL 9:
| Operation | Count | Avg Latency (us) | Min Latency (us) | Max Latency (us) | 50th Percentile (us) | 95th Percentile (us) | 99th Percentile (us) |
| READ | 472 | 672.27 | 177 | 56703 | 514 | 903 | 1331 |
| UPDATE | 528 | 621.27 | 214 | 12855 | 554 | 971 | 1224 |
| CLEANUP | 1 | 4702 | 4700 | 4703 | 4703 | 4703 | 4703 |
Results from a c4a-standard-4 instance (4 vCPUs, 16 GB RAM) on RHEL 9:
| READ | 534 | 312.96 | 156 | 8279 | 261 | 524 | 758 |
| UPDATE | 466 | 384.45 | 186 | 26543 | 296 | 498 | 821 |
| CLEANUP | 1 | 4138 | 4136 | 4139 | 4139 | 4139 | 4139 |
Lower average latencies on Arm: ~313 µs (READ) and ~384 µs (UPDATE).
Stable p50–p99 latencies indicate consistent performance.
Occasional max-latency outliers suggest transient spikes common in mixed workloads.
With YCSB built and results captured, you now have a baseline for MongoDB performance on Arm-based Google Axion C4A. You can iterate on dataset size, thread counts, and workloads (A–F) to profile additional scenarios and compare cost-performance across architectures.
