Now that MongoDB is installed on your Google Axion C4A Arm VM, verify that the server is running and accepting local connections.
Use mongosh to create a test database, run basic CRUD operations, and capture a quick insert-time baseline before you start benchmarking.
Open a shell session to the local MongoDB instance:
mongosh mongodb://127.0.0.1:27017
Switch to a new database and create a collection:
use baselineDB
db.createCollection("test")
This creates a new database named baselineDB and an empty collection called test.
Expected output:
switched to db baselineDB
{ ok: 1 }
Populate the collection with 10,000 timestamped documents:
for (let i = 0; i < 10000; i++) {
db.test.insertOne({
record: i,
status: "new",
timestamp: new Date()
Each document contains:
record: a counter from 0 to 9999status: "new"timestamp: the current date/time of insertionSample output:
{ acknowledged: true, insertedId: ObjectId('...') }
Verify read functionality by querying the first few documents:
db.test.find({ status: "new" }).limit(5)
This returns the first 5 documents where status is "new".
Update a specific document by changing its status:
db.test.updateOne({ record: 100 }, { $set: { status: "processed" } })
This finds the document where record is 100 and updates the status.
Expected output:
acknowledged: true,
matchedCount: 1,
modifiedCount: 1
Confirm that the document was updated:
db.test.findOne({ record: 100 })
Expected output:
_id: ObjectId('...'),
record: 100,
status: 'processed',
timestamp: ISODate('...')
The command below tells MongoDB to delete one document from the test collection, where record is exactly 100:
db.test.deleteOne({ record: 100 })
Verify deletion:
Expected output:
null
Measure how long it takes to insert 10,000 documents:
var start = new Date()
db.test.insertOne({ sample: i })
print("Insert duration (ms):", new Date() - start)
Sample output:
Insert duration (ms): 4427
Check the total number of documents in the collection:
db.test.countDocuments()
Expected output:
19999
The count 19999 reflects the total documents after inserting 10,000 initial records, adding 10,000 more (in point 8), and deleting one (record: 100).
For the sake of resetting the environment, this following command deletes the current database you are connected to in mongosh.
Drop the baselineDB database to remove all test data:
db.dropDatabase()
Expected output:
{ ok: 1, dropped: 'baselineDB' }
These baseline operations confirm that MongoDB is functioning properly on your GCP Arm64 environment. Using mongosh, you validated inserts, queries, updates, deletes, and basic performance timing. Your instance is now ready for benchmarking or application integration.
