Explore related resources
Give feedback
AI-assisted
Close
Which machine type should I select for the VM?
Select the C4A series and the c4a-standard-4 machine type, which provides four vCPUs and 16 GB of memory.
Which MongoDB binaries do I download for the VM?
Download the Arm64 (aarch64) MongoDB binaries for RHEL 9.3 and extract them on your C4A instance.
How do I verify that MongoDB is running locally?
Run mongosh mongodb://127.0.0.1:27017. A successful connection and mongosh prompt confirm that the server accepts local connections.
What quick baseline should I capture before running YCSB?
Use mongosh to create the baselineDB database and test collection. Perform the CRUD checks and record the insert timings shown by the commands.
What should I check after building YCSB?
Confirm that Maven builds the MongoDB binding without errors. Then, run the load phase and verify that it inserts the default 1,000 records and prints results to the terminal.
