Install MongoDB and mongosh on Ubuntu Pro 24.04 LTS (Arm64). You will download the binaries, add them to your PATH, create data and log directories, and start the server locally to verify the setup.
For this exercise, mongod runs locally and access control is disabled by default. Keep the server bound to 127.0.0.1 until you configure users and authentication. To accept remote connections later, set --bind_ip (or bindIp in the config) and enable authorization.
Install the required system packages to support MongoDB:
sudo apt update
sudo apt install -y curl wget tar fio openssl libcurl4 net-tools
Fetch and unpack the MongoDB binaries for Arm64:
wget https://fastdl.mongodb.org/linux/mongodb-linux-aarch64-ubuntu2404-8.0.12.tgz
tar -xvzf mongodb-linux-aarch64-ubuntu2404-8.0.12.tgz
sudo mv mongodb-linux-aarch64-ubuntu2404-8.0.12 /usr/local/mongodb
Enable running MongoDB from any terminal session:
echo 'export PATH=/usr/local/mongodb/bin:$PATH' | sudo tee /etc/profile.d/mongodb.sh
source /etc/profile.d/mongodb.sh
Create the database data and log directories and assign ownership to your user:
sudo mkdir -p /var/lib/mongo
sudo mkdir -p /var/log/mongodb
sudo chown -R $USER:$USER /var/lib/mongo /var/log/mongodb
Start mongod in the background and write logs to /var/log/mongodb/mongod.log:
mongod --dbpath /var/lib/mongo --logpath /var/log/mongodb/mongod.log --fork
Sample output:
about to fork child process, waiting until server is ready for connections.
forked process: 3356
child process started successfully, parent exiting
mongosh is the MongoDB shell for running queries and database operations.
Download and install the MongoDB shell for Arm64:
wget https://downloads.mongodb.com/compass/mongosh-2.3.8-linux-arm64.tgz
tar -xvzf mongosh-2.3.8-linux-arm64.tgz
sudo mv mongosh-2.3.8-linux-arm64 /usr/local/mongosh
Add mongosh to the system PATH:
echo 'export PATH=/usr/local/mongosh/bin:$PATH' | sudo tee /etc/profile.d/mongosh.sh
source /etc/profile.d/mongosh.sh
Confirm that MongoDB and mongosh are installed and available:
mongod --version
mongosh --version
You should see output similar to:
db version v8.0.12
Build Info: {
"version": "8.0.12",
"gitVersion": "b60fc6875b5fb4b63cc0dbbd8dda0d6d6277921a",
"openSSLVersion": "OpenSSL 3.0.13 30 Jan 2024",
"modules": [],
"allocator": "tcmalloc-google",
"environment": {
"distmod": "ubuntu2404",
"distarch": "aarch64",
"target_arch": "aarch64"
2.3.8
Connect to the local instance and verify an interactive prompt:
mongosh mongodb://127.0.0.1:27017
Current Mongosh Log ID: 68b573411523231d81a00aa0
Connecting to: mongodb://127.0.0.1:27017/?directConnection=true&serverSelectionTimeoutMS=2000&appName=mongosh+2.3.8
Using MongoDB: 8.0.12
Using Mongosh: 2.3.8
mongosh 2.5.7 is available for download: https://www.mongodb.com/try/download/shell
For mongosh info see: https://www.mongodb.com/docs/mongodb-shell/
The server generated these startup warnings when booting
2025-09-01T09:45:32.382+00:00: Using the XFS filesystem is strongly recommended with the WiredTiger storage engine. See http://dochub.mongodb.org/core/prodnotes-filesystem
2025-09-01T09:45:33.012+00:00: Access control is not enabled for the database. Read and write access to data and configuration is unrestricted
2025-09-01T09:45:33.012+00:00: This server is bound to localhost. Remote systems will be unable to connect to this server. Start the server with --bind_ip <address> to specify which IP addresses it should serve responses from, or with --bind_ip_all to bind to all interfaces. If this behavior is desired, start the server with --bind_ip 127.0.0.1 to disable this warning
2025-09-01T09:45:33.012+00:00: Soft rlimits for open file descriptors too low
2025-09-01T09:45:33.012+00:00: For customers running the current memory allocator, we suggest changing the contents of the following sysfsFile
2025-09-01T09:45:33.012+00:00: We suggest setting the contents of sysfsFile to 0.
2025-09-01T09:45:33.012+00:00: Your system has glibc support for rseq built in, which is not yet supported by tcmalloc-google and has critical performance implications. Please set the environment variable GLIBC_TUNABLES=glibc.pthread.rseq=0
test>
With this verification complete, proceed to MongoDB baseline testing on your Azure Cobalt 100 VM.
