In this section, you will measure MongoDB’s performance in real time. You will install the official MongoDB database tools, start MongoDB and run a script to simulate heavy load. With the script running you will then measure the database’s live performance using mongotop and mongostat.
wget https://fastdl.mongodb.org/tools/db/mongodb-database-tools-ubuntu2404-arm64-100.13.0.deb
sudo apt update
sudo apt install -y ./mongodb-database-tools-ubuntu2404-arm64-100.13.0.deb
echo 'export PATH=$PATH:~/mongodb-database-tools-ubuntu2404-arm64-100.13.0/bin' >> ~/.bashrc
source ~/.bashrc
These commands download and unpack MongoDB’s official monitoring tools (mongotop & mongostat), then add them to your PATH so you can run them from any terminal.
mongostat 2
This prints a line every two seconds with key metrics. Press Ctrl+C to stop.
Connect explicitly if needed. If your instance is on a non‑default host or port, provide them:
mongostat --host 127.0.0.1 --port 27017 2
insert query update delete getmore command dirty used flushes vsize res qrw arw net_in net_out conn time
8 16 8 8 182 1|0 0.0% 0.0% 0 3.54G 146M 0|0 0|0 34.0k 172k 11 Sep 4 04:57:56.761
4 8 4 4 98 1|0 0.0% 0.0% 0 3.54G 146M 0|0 0|0 18.3k 116k 11 Sep 4 04:57:58.762
4 9 4 4 99 1|0 0.0% 0.0% 0 3.54G 146M 0|0 0|0 18.3k 117k 11 Sep 4 04:58:02.760
8 17 8 8 202 1|0 0.0% 0.0% 0 3.54G 146M 0|0 0|0 37.0k 183k 11 Sep 4 04:58:04.762
4 9 4 4 103 2|0 0.0% 0.0% 0 3.54G 146M 0|0 0|0 19.0k 119k 11 Sep 4 04:58:06.760
8 15 7 7 183 1|0 0.0% 0.0% 0 3.54G 146M 0|0 0|0 33.5k 171k 11 Sep 4 04:58:08.761
5 11 5 5 126 1|0 0.0% 0.0% 0 3.54G 146M 0|0 0|0 23.1k 135k 11 Sep 4 04:58:10.760
6 12 6 6 133 1|0 0.0% 0.0% 0 3.54G 146M 0|0 0|0 24.5k 138k 11 Sep 4 04:58:12.760
7 14 7 7 190 1|0 0.0% 0.0% 0 3.54G 146M 0|0 0|0 34.1k 174k 11 Sep 4 04:58:14.761
4 9 4 4 108 2|0 0.0% 0.0% 0 3.54G 146M 0|0 0|0 19.6k 123k 11 Sep 4 04:58:16.760
9 18 9 9 220 2|0 0.0% 0.0% 0 3.54G 147M 0|0 0|0 39.7k 195k 11 Sep 4 04:58:18.760
4 8 4 4 112 0|0 0.0% 0.0% 0 3.54G 147M 0|0 0|0 20.1k 125k 11 Sep 4 04:58:20.762
7 15 7 7 179 1|0 0.0% 0.0% 0 3.54G 147M 0|0 0|0 32.4k 169k 11 Sep 4 04:58:22.760
5 11 5 5 158 1|0 0.0% 0.0% 0 3.54G 147M 0|0 0|0 28.1k 155k 11 Sep 4 04:58:24.761
5 9 4 4 117 2|0 0.0% 0.0% 0 3.54G 147M 0|0 0|0 21.1k 128k 11 Sep 4 04:58:26.761
4 8 4 4 117 1|0 0.0% 0.0% 0 3.54G 147M 0|0 0|0 20.7k 127k 6 Sep 4 04:58:28.761
*0 *0 *0 *0 0 0|0 0.0% 0.0% 0 3.54G 147M 0|0 0|0 98b 53.3k 6 Sep 4 04:58:30.762
*0 *0 *0 *0 0 1|0 0.0% 0.0% 0 3.54G 147M 0|0 0|0 87b 51.0k 3 Sep 4 04:58:32.761
qrw = queued read | queued writearw = active read | active writeHere is a summary of benchmark results collected on an Arm64 D4ps_v6 Ubuntu Pro 24.04 LTS virtual machine
| insert | query | update | delete | getmore | command | dirty | used | flushes | vsize | res | qrw | arw | net_in | net_out | conn | time |
| 50 | 0 | 0 | 0 | 0 | 7/0 | 0.0% | 0.0% | 0 | 3.53G | 141M | 0/0 | 0/0 | 10.9k | 57.8k | 10 | Sep 4 04:57:18.761 |
| 404 | 13 | 4 | 4 | 71 | 8/0 | 0.0% | 0.0% | 0 | 3.53G | 143M | 0/0 | 0/0 | 96.3k | 114k | 10 | Sep 4 04:57:20.761 |
| 7 | 14 | 7 | 7 | 108 | 2/0 | 0.0% | 0.0% | 0 | 3.53G | 143M | 0/0 | 0/0 | 21.8k | 118k | 10 | Sep 4 04:57:22.760 |
| 6 | 12 | 6 | 6 | 112 | 0/0 | 0.0% | 0.0% | 0 | 3.53G | 143M | 0/0 | 0/0 | 21.9k | 120k | 10 | Sep 4 04:57:24.760 |
| 8 | 16 | 8 | 8 | 136 | 1/0 | 0.0% | 0.0% | 0 | 3.53G | 144M | 0/0 | 0/0 | 27.1k | 137k | 10 | Sep 4 04:57:26.762 |
| 5 | 10 | 5 | 5 | 93 | 2/0 | 0.0% | 0.0% | 0 | 3.54G | 144M | 0/0 | 0/0 | 18.2k | 111k | 11 | Sep 4 04:57:28.760 |
| 7 | 15 | 7 | 7 | 135 | 0/0 | 0.0% | 0.0% | 0 | 3.54G | 144M | 0/0 | 0/0 | 26.5k | 139k | 11 | Sep 4 04:57:30.761 |
| 5 | 11 | 5 | 5 | 102 | 1/0 | 0.0% | 0.0% | 0 | 3.54G | 144M | 0/0 | 0/0 | 19.7k | 118k | 11 | Sep 4 04:57:32.761 |
| 7 | 16 | 10 | 7 | 138 | 2/0 | 0.0% | 0.0% | 0 | 3.54G | 145M | 0/0 | 0/0 | 27.0k | 143k | 11 | Sep 4 04:57:34.761 |
| 5 | 10 | 5 | 5 | 104 | 1/0 | 0.0% | 0.0% | 0 | 3.54G | 145M | 0/0 | 0/0 | 20.1k | 121k | 11 | Sep 4 04:57:36.761 |
You have now successfully benchmarked MongoDB on an Azure Cobalt 100 Arm64 virtual machine.
